| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22RE Replacement Options
__________________
1998 Tacoma Standard Cab 4x4 -5 Speed -2.7L 3RZ-FE -80,000 Miles -custom ISR Mod -Purolator Fuel Filter -Royal Purple -Marlin Crawler Shift Stuff -Lots of Plans -No Money |
#2 (permalink) |
What transmission do you plan to run? If you have the stock 5 speed now, its life will be shortened behind a 200 hp engine.
__________________
-Glenn- |
#3 (permalink) |
I've heard that the G52 can take a bit more than 200, but I might be misinformed.
What if I go with the 5MGE? Do you think it'll survive against the small increase in HP (170-ish)?
__________________
#4 (permalink) |
You definetly should use a W-series tranny behind any of those sixes....An R-series would be ideal.
Really though..I'd swap in a nice 3RZFE.... |
#5 (permalink) |
R-Series?? I don't know about this one.
But I did hear of the W56 being a common swap for the stock 5-Speed
__________________
#6 (permalink) |
R series trannies came in Turbo trucks(22RTE), 3VZE and 5VZFE trucks. They are also found in Turbo Supra's(1986.5-1992 MA70 series).
#7 (permalink) |
Yeah, an R series would be good. R150 or R151 I believe it is. I am not sure, but I think they come behind the 3.4 Tacoma's, which put out 190 hp.
Don't you already have a W56? That is what my '89 has.
__________________
-Glenn- |
#8 (permalink) |
yeah, w56 is the stock 5-speed behind a 22RE.
fingerman, just out of curiousity, why did you rule out the 3.4 v6? they are awesome engines, imho. if my engine died, my short list would be: 1. a 3.4 (5VZFE) 2. another 22RE 3. a 2.7 (3RZFE--the new 4 cylinder...keep the simplicity of a 4 cylinder, but get much more power than the 22RE). i'd prolly do number 1 unless i couldn't find one for a reasonable price...i'd prolly run my w56 behind it until it died (which i suspect would not be for a long time) and then replace it with an R series tranny.
__________________
Stan Marshall 1994 4x4 22RE/w56 SWB pickup |
#9 (permalink) |
Hmm.. Well I just timelined it and I found that my truck has a W56
with a RF1A transfer case? Does that sound right? Dammit I haven't even CONSIDERED researching trannies. I guess I better read up.
__________________
1998 Tacoma Standard Cab 4x4 -5 Speed -2.7L 3RZ-FE -80,000 Miles -custom ISR Mod -Purolator Fuel Filter -Royal Purple -Marlin Crawler Shift Stuff -Lots of Plans -No Money Last edited by FingerMan20; 07-08-2005 at 09:23 PM. |
#10 (permalink) | |
Quote:
__________________
#11 (permalink) |
yep...that sounds right.
btw, your transfer case is absolutely bullet proof. you do not need to worry about replacing that no matter which engine you go with.
__________________
#12 (permalink) |
But the 3RZ... Any info on that swap?
And btw, I am opting for the older 6Cyl's because it has been done, therefore I think it might be within my grasp a bit better than trying to break new ground with another swap.
__________________
1998 Tacoma Standard Cab 4x4 -5 Speed -2.7L 3RZ-FE -80,000 Miles -custom ISR Mod -Purolator Fuel Filter -Royal Purple -Marlin Crawler Shift Stuff -Lots of Plans -No Money Last edited by FingerMan20; 07-08-2005 at 09:26 PM. |
#13 (permalink) | |
Quote:
i have a buddy with a 3.4 tacoma...man, i really like that engine...if i could take that and his e-locker out of his tacoma and put it in my pickup...drewl... don't think he'd go for that, though.
__________________
Stan Marshall 1994 4x4 22RE/w56 SWB pickup Last edited by LittleRedToyota; 07-08-2005 at 09:32 PM. |
#14 (permalink) | |
Quote:
__________________
#15 (permalink) |
hehe...btw, the 3.4 for a 22RE swap has been done...i think off-road solutions might even make a kit for it.
__________________
#16 (permalink) |
ORS does make a kit, but from what I've already read, it seems impossible. Plus it is for the 3VZ to 5VZ, so their kit does me no good...
Another thing I stumbled across is a "conversion kit" for the 5MGE. From what I have read it is a stroker kit, with other mods, and it boosts HP in the 5MGE from stock 160 to 200 or more. This is very interesting, because I could do this, with much less cost than the 3.4L swap, and try out the 160 HP, mileage wise, and then add power if I want too.
__________________
#17 (permalink) |
Anyone else hear about the 6M conversion kit for the 5M engine? I've heard it called a 2.9 kit, or something similar.
__________________
#18 (permalink) |
Anyone??
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 89 4runner tailgate replacement options | slamigo | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 09-06-2007 01:14 PM |
| Siren replacement advice: What are my options? | rimpainter.com | Alarm Systems | 4 | 10-21-2006 09:45 PM |
| OEM leather replacement options? | HaveBlue | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 09-19-2006 04:32 PM |
| Replacement Battery Options.... | LSUMatt1514 | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 07-19-2005 05:12 PM |
