22re leaking oil
22re leaking oil
on the passenger side of the engine, small slow oil leak. i just had the
oil pressure switch replace by a dealership last week.
i am no mechanic......but......is there anything i can check? i can't tell where it is coming from. do those switches go bad that quick.....maybe defective?
thanks in advance
thanks in advance
Location: White Mountains, Arizona (Yes it does snow in AZ)
Could be defective, though they usually just don't send a signal... not leak.
Maybe the mechanic boogered it. Right next to the filter right? Is your oil filter leaking? I removed the oilf filter and changed the oil when I replaced my sender.
right....next to the filter.
what is the best way to change the filter on the 22re......from below.....above??
are there any problem areas......pain gasket ? etc.
thanks again
thanks again
thanks again
thanks again
jasonty
41
12-23-2018 01:00 PM
