| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22re help (just did the timing chain)
#2 (permalink) |
did you set the timing with a timing light (and the diagnostic terminals TE1 and E1 jumpered) after putting it all back together?
__________________
Stan Marshall 1994 4x4 22RE/w56 SWB pickup |
#3 (permalink) |
timing issue... it needs to be set correctly.. the connector must be properly shorted or it will make the values wrong.. here is a small part stolen from www.4crawler.com about it:
Start up the vehicle. The timing is probably off since the distributor was moved. To get the vehicle to idle smoothly adjust the distributor freehand or set the timing the right way. - With the timing test connector (TE+ E+) shortedn set the timing to 5° BTDC/22RE or 0°BTDC/22R |
#4 (permalink) | |
Quote:
but i put everything back the way it was originally
__________________
88 CRX Si Retired 90 CRX Si Benson Turbo b16a 94 Yota 4x4 downey 3" lift |
#5 (permalink) |
Yup Id say timming is off. GO rent a timming light.
#6 (permalink) |
that doesn't guarantee the timing is right...that'll get it close enough to run, but not necessarily to run well. i don't think you can really get around needing to set the timing with a light. some people claim to be able to do it by ear, but...
you might be able to rent one from autozone. not sure where you are, but, if you are around pittsburgh, you can use mine. if you are elsewhere, maybe there is someone around you who will lend you one? or consider buying one...they really aren't that expensive and come in handy.
__________________
#7 (permalink) | |
Quote:
When you start the truck and put the jumper in it should read 5* on the button. I think you have it set to advanced from the begining. Go back and pop the dist. cover and rotate the crank till it gets to 0* and see where the rotor is pointing.
__________________
Brad Work is for those who don't know how to plunder!! 92x-cab dlx 4x4 22RE, Pacesetter header, everything else is so stock it's not funny, cause I don't have the money! 04 F150 FX4 SuperCrew Last edited by PirateFins; 10-07-2005 at 01:14 PM. |
#8 (permalink) |
go buy a timing light... they are > $15 at harbor freight!!!!! http://www.harborfreight.com/cpi/cta...temnumber=3343
#9 (permalink) | |
Quote:
. thanks guys
__________________
#10 (permalink) |
get teh valves adjusted.... or do it yourself..... i have done everything to my own truck... its actually i nthe garage right now in pieces, i am doing my timing chain right now... i think its pretty easy, but its a hell of a lot of bolts....
i wont touch my valves though, i know how to do it, but i swear, its a 50/50 chance, i never get it right.... im going to pay someone to adjsut them after i finish... i get it close, think its off, readjsut it, then its worse..... |
#11 (permalink) | |
Quote:
i need to adjust the valves but tonight, im enjoying some heineken
__________________
#12 (permalink) |
Use a timing light.
This is the procedure I used on my 1990 22re with 128k. First set #1 to TDC by turning the main pulley to 0* and make sure the distributor is pointed at the #1 cylinder. Then fire it up and with a timing light, rotate the dizzy until it is 12* BTDC. (The service manual will say jump a connector and adjust timing to 5* BTDC but 12* is what 5* it is unjumped. ) Adjust the idle after the engine reaches operating temp and you're done! Drive around and enjoy the smoothe power. HTH
__________________
1990 Toyota Pickup 2WD [Dark Gray Metallic (179)] --Short bed/Std Cab, Amsoil panel filter + deckplate mod, diy ground kit, autometer tach, L46 4 speed/22RE, 195/75-14 Michelin LTX M/S 1984 Mazda RX-7 GSL-SE [VG Beige] --K&N Panel Filter, RB cat-back, 13" Grant GT wheel, spare tire/jack delete 1983 Mazda RX-7 [Dover White] --302 H.O./T5 swap in progress |
#13 (permalink) |
Why would adjusting your own valves seem daunting? It's not too hard to do and the only real critical part is the exhaust valves, since they run hotter and can benefit from a teeny bit more slack (.013) to allow them to cool more when they sit on the seats.
With the engine off and at operating temp, I set the timing mark to fire on 1 and adjust both valves for #1, the intake for #2 and the exhaust for #3; Then I turn the crank 360 around to fire on #4 and adjust both valves for #4, the intake for #3 and the exhaust for #2. Easy. BTW: Intakes are at .008 and the exhausts, although technically to be set for .012 will be OK at .013. Tight exhaust valves overheat and can burn, which takes a nasty gouge out of one side, drops compression for its cylinder and makes overall life for your engine hard. BTW: The only mechanic I trust is ME. |
| Tags |
| 22re |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Timing Chain 22re | cweich | 86-95 Trucks & 4Runners | 1 | 12-22-2006 05:12 PM |
| 22re timing chain | 4RunnerLVR86 | 86-95 Trucks & 4Runners | 5 | 10-07-2006 11:15 AM |
| Timing Chain, 22RE | AH64ID | 86-95 Trucks & 4Runners | 26 | 04-17-2006 01:27 PM |
| 22re timing chain/set timing/rtv/headremoval | brendonv | Maintenance & Repair Archives | 4 | 09-20-2005 07:18 AM |
| 22re timing chain | Brendan | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 04-25-2004 10:03 AM |
