| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
#2 (permalink) |
Sory to tell you this but you have lost a piston ring, had the same thing happen on my 4runner. If your lucky it wont do any damage to the cylinder walls.
__________________
'86 4runner 22RE, 5-speed, LC Street EFI head w/ cam, LC Pistons, ARP Head Studs, Downey header, Dynomax 2 1/4" full exhaust, VDO water temp guage, 01-03 Tacoma cd\tape radio with 10" Bazzoka, Downey 2" rear springs, GDI radiator, Torus fan DONE!!!! '68 Ford Mustang Fastback Daily driver with a built 289 and a streetfighter trans.(Retired) 98 Subaru Outback-Took over daily driving duties MicroMatic.com Waco93.com |
#3 (permalink) | |
Quote:
#4 (permalink) |
Mine dissapeared, no trace of it. Did not do any damage to the piston, cylinder walls, head or anything. The motor only had 30,000 on a rebuild by the previous owner.
It not uncommon to blow rings when head work is done because sometimes when cylinders go from having no-little psi to having 170 psi bad things can happen.
__________________
#5 (permalink) | |
Quote:
#6 (permalink) |
Yea just getting the pan off sure did suck, I should of pulled the motor.
__________________
#7 (permalink) |
I feel your pain! I just had my truck up for sale, and then decided to keep it. My #2 cylinder is trashed. 60psi dry, and 80psi wet. All others are at 120.
Is it dangerous for the motor to drive with a bad valve or possibly missing piston ring? The reason I ask is I would like to drive the truck back to my mom's house where I have a garage to work in (mechanic here wants close to $900), but she is 80 miles away. I'd limp it at no more than 50mph... but I don't want to make the situation worse.
__________________
1987 Xtra Cab (4x4) - (SOLD) 22r, Rancho RS 5000, 15x8 American Racing AR-23s w/ 31x10.5 BFGoodrich A/T's, 2.25" exhaust w/ 23 1/8" glasspack, Explorer Pro Comp Prerunner bar/ Hella 500's |
#8 (permalink) |
It all depend, every situation is different. If the valve was hanging into the cylinder then I would say do not drive it.
When I lost the piston ring on my 4runner I drove it for over 100 miles like that, I figured that whatever damage was done so might as well go to for another week driving it.
__________________
#9 (permalink) |
Borrow or buy a 12 mm wrench at Wally World and pop off the valve cover. See if your valves keepers are all in place so you know a valve isn't trying to migrate into the cylinder (they don't do any good in there). If that checks out, the only other damage I can think of is a broken ring scratching up the inside of the cylinder wall and piston. If that's your problem, the damage is probably done. Open up your oil fill cap w/motor running and see if you get a bunch of pressure blowing out. It will be obvious.
With any luck you just have a burned valve, which only makes it annoying to drive. My bad cylinder psi was about the same, but as you read there is alot of compression going into the crankcase. When you open the oil cap, the engine should actually drop in rpm and stutter a bit more due to extra air being fed into the intake via the pcv tubes on top the valve cover. If that's the case, you are most likely losing air/fuel out the exhaust, instead of into the crankcase, as is my case. I put 300 miles on it before I realized the problem was more severe than a tuning issue. I'm opening it up Sunday, I'll let you know what I find.
__________________
1987 4-Runner 305,000 miles 1990 Dodge 4x4 Cummins Diesel 2003 VW Jetta Wagon, TDI Last edited by yotafreakshow; 09-10-2004 at 06:10 PM. |
#10 (permalink) |
What about stuck open pressure from the oil pump? Not sure because mine blew the oil out from around the filter and this was the problem. I know the dipstick came out but never ran it long for obvious reasons.
__________________
Former trucks- 89 & 86 4Runners http://www.va4roc.com |
#11 (permalink) |
Nope, trashed rings in cyl. #4. The top one was worn to about half it's normal width, and the bottom one was broken in about 15 places, and all pieces stayed in the groove...unbelievable, there was no damage to the cylinder walls or piston. Whatever they are made of must be alot softer than the steel used in the block. The other 3 clylinders looked fine. I'll get her up and running tommorow sometime.
SoCal4Running, I see how you could "lose" a ring. Some of the pieces were only 2 or 3mm long. A broken top ring could go right out the exhaust bit by bit.
__________________
1987 4-Runner 305,000 miles 1990 Dodge 4x4 Cummins Diesel 2003 VW Jetta Wagon, TDI |
#12 (permalink) |
Besure to check the ring groove in the piston itself, they can "widen" over time, especially with ring pieces movin all around.
Are you going to use a Toyota brand HG? Worth the $$
__________________
#13 (permalink) |
I'm using a Victor Reinz (sp?) brand gasket. Napa's house brand I believe. I put a new timing chain in my '89 pu 60k miles ago using the same one and haven't had any problems.
Piston grooves seemed fine, I used a broken ring to scrape the carbon out of them and the fit was snug, but allowed movement. I'll check the clearance with a feeler guage when the new ones are in.
__________________
#14 (permalink) |
It's ALIVE!!!!!!!!
Success today. New rings and rod bearings installed, she runs awesome. No leaks. Just need to break her in and see what she's really got.
__________________
#15 (permalink) |
Sweet, glad to here. I am still cleaning the oil off the underside of my hood. lol
__________________
#16 (permalink) | |
Quote:
Sorry I find this funny. Glad everything worked out for you |
#17 (permalink) |
Hey guys, just curious if the valve is moving into the cylinder, how would that look exactly. Will something be disconnected, will the spring be loose no matter what, etc? I am going to take it apart this weekend, and if viable drive it down the following weekend.
__________________
#18 (permalink) | |
Quote:
Just make sure there are 2 valve keepers in each of the valve spring retainers. The keepers are like little wedges that fit into a groove around the top of the valve stems, inside the retainers. The top of the keepers should be about flush with the top of the spring retainer. Just make sure the retainer area on top of all 8 valves look the same and you should be fine, of course the rocker arms will be pushing some of them down.
__________________
1987 4-Runner 305,000 miles 1990 Dodge 4x4 Cummins Diesel 2003 VW Jetta Wagon, TDI Last edited by yotafreakshow; 09-17-2004 at 08:49 PM. |
| Tags |
| 22r, 22re, 66, baffle, blowing, cap, cover, crankcase, cylinder, dipstick, mustang, oil, pressure, rings, scratching, valve, vent |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22re wont crank | prerunxj93 | 86-95 Trucks & 4Runners | 6 | 07-10-2006 06:26 AM |
| 22RE Crank/no start | Crash_AF | 84-85 Trucks & 4Runners | 4 | 06-08-2006 11:08 AM |
| 22Re number of crank pulleys | yotaknows | 86-95 Trucks & 4Runners | 3 | 04-01-2006 09:52 AM |
| crank case vent hose | george | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-07-2005 02:06 PM |
| 22RE crank, rods trashed | MO Diver | Maintenance & Repair Archives | 1 | 10-20-2004 02:55 PM |
