| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22re clatter
#2 (permalink) |
what did you set the clearances to on the rockers? i like to do .007 intake, .011 exhaust.
your adjuster screws could also be worn out.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
#3 (permalink) |
set intake .008 exaust .012 but like i said i've set them tight and loose... what do you mean adjusters may be worn? i did notice when i set them and then tighten the nut they would end up slightly looser. my clatter is above 2000rpm but only with very little torque on the moter ie:stomp it, it stops back off, it stops(just cruising)...
OH YEAH! where do you find a .006,.007 feeler guage? thanks for the reply LONESTAR |
#4 (permalink) |
most sets will have ones that small, i think mine go down to .003 or .004"
don't set them that tight though! the adjuster is the little screw part that you turn in or out to adjust, it's just a special stud. often times they get flat spots and make a lot of noise.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Engine clatter | drguitarum2005 | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 11-25-2006 10:33 PM |
| 22re Engine Clatter?? | ToyBoy05 | 86-95 Trucks & 4Runners | 6 | 10-02-2006 02:11 PM |
| valve clatter help 89 22re (post searches) | trythis | 86-95 Trucks & 4Runners | 1 | 05-28-2006 07:38 PM |
| Random Engine Clatter | dstrick32 | 86-95 Trucks & 4Runners | 3 | 01-09-2006 10:15 AM |
| 22re clatter opinions | lonestar | 86-95 Trucks & 4Runners | 10 | 11-28-2005 06:03 PM |
