22re cam
Old 09-09-2003, 08:35 PM
colt ar's Avatar
22re cam
do you have a cam in your 22re? How does it idle ?
Old 09-10-2003, 04:57 AM
invincibletoy's Avatar
I have a c270 cam from DOA Racing. I love it.
Call Tim @ DOA
www.doaracingengines.com
Old 09-10-2003, 07:56 AM
flecker's Avatar
Location: White Mountains, Arizona (Yes it does snow in AZ)
I have a crane cam:
1. Mechanical Follower Camshafts for Non-Emissions Controlled Vehicles
Application Series & Grind Number
Good idle, daily usage and off road, performance and fuel efficiency, good low end torque, 2000-2600 cruise RPM, 8.75 to 10.5 compression ratio advised. Basic RPM 1400-4800 T20-262-2-10
Cam Specifications
Degrees Duration @ 1mm Int./Exh. Degrees Advertised Duration Int./Exh. Degree Lobe Separation Open/Close @ 1mm Valve Lift Int./Exh. Lash Hot Int./Exh. Gross Lift Int./Exh.
220
230 262
272 110 5 35
50 0 .20
.25
(.008)
(.010) 10.57
10.92
(.416)
(.430)
Valve Train Components
Camshaft 704-0010*
Followers We recommend the use of the 22R-22RE followers with the insert-type contact pad for best wear and reliability; as the 20R type is not advised. The Toyota part numbers for these are: 13801-35101 rocker follower, 90913-05019 adjusting screw, 90179-08049 locking nut.
Great idle!
Old 09-10-2003, 08:45 AM
Yoda's Avatar
We used the TRD stage 1 cam (emmissions acceptable)
Idles great, good power ( for a 4 banger i guess)
RatOmeter
10-22-2015 03:17 PM
Iceman4193
08-28-2015 08:43 PM
nonstop
7
08-11-2015 09:26 AM
Fakayayou
08-09-2015 12:47 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: 22re cam
