22re a/c idle
22re a/c idle
:pat: Need some help guys.My a/c works fine,my a/c idle vsv(vacuum switching valve)is good, but won't energize when the a/c is on.I can run 12v directly to it and it kicks on.My question is,will it cause any damage to the vsv if I hook up a switch on the dash to turn it on manually when the a/c on.Or,can I run a jumper wire to the compressor so it only comes on when the compressor kicks in?If either one of these methods would cause damage to the vsv or compressor,let me know.Thanks guys!22re, 5spd,4x4
montanatruck
02-26-2017 07:07 AM
