YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 02-02-2005, 06:31 PM   #1 (permalink)
22r turbo head swap
what are the pro's and con's of installing a 22re head onto a 22rte (turbo)
short block engine.
the non-turbo head has a smaller combustion chamber, what kind of compression ratio will I end up with?
finefiftynine is offline
Sponsored Links
To remove this ad, register today!
Old 02-02-2005, 06:48 PM   #2 (permalink)
somebody out there has to have tried this before, all opinions are welcome!
Old 02-02-2005, 06:52 PM   #3 (permalink)
kyle_22r's Avatar
what exactly do you want? yes, it'll bump up compression but you want lower compression for a turbo, and if the engine is N/A you'll still have the dished pistons so it'll have lower compression than you'd want for a non-turbo engine.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 02-02-2005, 06:57 PM   #4 (permalink)
will the compression be to high to be able to run the stock turbo setup?
Old 02-03-2005, 04:28 PM   #5 (permalink)
Send a message via AIM to ETN4runner
If i were gonna build a 22r turbo i would use an early block and head and use late model pistons to decompress it. An early 22r has mini dome pistons and hemispherical combustion chambers so the flat top pistons would be decompressing it.
ETN4runner is offline
Old 02-03-2005, 05:42 PM   #6 (permalink)
kyle_22r's Avatar
that'd be a decent idea if you have an early engine sitting around begging to be built, as long as it's an '83 or '84 head(efi compatible)
__________________
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 02-03-2005, 05:47 PM   #7 (permalink)
i have a unique situation. My 85 runner has an 84 22re out of a celica in it so if it ever comes down to me building it, thats my plan.
Old 02-04-2005, 04:18 PM   #8 (permalink)
The engine that we are working on is a 1987 4-runner turbo w/auto trans. (22rte).
The engine overheated so we pulled the head and found the headgasket to be blown and the head was warped. We have a head off of a 1985 4x4 pickup (22re) EFI that we thought about putting onto the turbo bottom end to raise the compression.
We live in south eastern Idaho so we usualy drive between 4500-8500 feet above sea level.
The compression ratio should fall somewhere between 8.25:1-8.75:1, at this elevation it doesn't hurt to run more compression on a normal engine but we weren't sure on a turbo engine. With boost pressures between 6-8 psi it should stay together, we hope!
I guess the worst thing that will happed is we will blow the head gesket again.
The turbo head is still good it just needs resurfaced.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
22R Turbo MolokaiRider General Vehicle Related Topics (Non Year Related) 3 07-16-2007 04:39 PM
Anyone turbo their 22r duburban 86-95 Trucks & 4Runners 9 01-21-2007 07:30 AM
does 22r head = 22re head imtxn 86-95 Trucks & 4Runners 16 12-11-2006 08:30 AM
22RE and 22R Head swap...compatible years? Mudd Runna 95.5-2004 Tacomas & 96-2002 4Runners 5 04-13-2003 06:53 PM
22R turbo 1lowtaco 95.5-2004 Tacomas & 96-2002 4Runners 1 09-16-2002 09:11 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
