22R Spark Plug Gap - YotaTech Forums
Go Back   >
22R Spark Plug Gap
LinkBack Thread Tools Search this Thread
Old 07-31-2004, 01:50 PM   #1
22R Spark Plug Gap
I am swapping out my spark plugs today and I am told to check the emission control sticker for the proper spark plug gap spacing. Well, my 81 4x4 with the 22R does not say anything on the sticker, owners manual or anywhere else for that matter. Does anyone know? For now, I have changed the wire and distributor cap and rotor but I am waiting to do the plugs themselves. Any help would be greatly appreciated.
Thanks
Steve
beachbrum is offline   Reply With Quote
Old 08-01-2004, 02:50 PM   #2
AKennedy87's Avatar
it was .31 or .031 whatever one is the correct decemel, on my 87.
AKennedy87 is offline   Reply With Quote
Old 08-02-2004, 10:21 AM   #3
Secret Squirell's Avatar
.032 on mine (1987 22re)
Secret Squirell is offline   Reply With Quote
Old 08-02-2004, 10:01 PM   #4
Spark Plugs are in now BUT.....
Thanks for the help with the gap spacing. I have all the plugs in, new wires, new distributor cap and new rotor. Only now when I start the engine it cranks a lot longer than it used to prior to changing it all out.
Would this be an issue with a bad wire connection, bad gap spacing, or maybe the plugs aren't tight enough? This is the first time I have ever replaced spark plugs on any car so I was not sure what to expect. Is there anything I can do to see if I can make it start easier?
Thanks in advance!
Old 08-11-2014, 08:03 AM   #5
ToyotaTank15's Avatar
I would double check and make sure your timing is right. Factory seeing for the advance is set to "0". I had the same problem so I advanced it between "0" and "5". Mine starts up within 2 turn overs now.
ToyotaTank15 is offline   Reply With Quote
CODE issue. SOS HELP! raptor510 86-95 Trucks & 4Runners 18 11-25-2016 05:51 PM
94 pickup 22re sluggish bogging idle issues montanatruck 86-95 Trucks & 4Runners 14 04-21-2016 05:52 PM
Rough idle mystery Eggslinger 86-95 Trucks & 4Runners 16 01-19-2016 08:20 PM
Toyota 3.0 extremely sluggush Alex Bessinger 86-95 Trucks & 4Runners 21 08-31-2015 10:17 AM
22r Loss of Power and Clicking. cars-guy Pre 84 Trucks 1 07-11-2015 08:51 PM
Tags
1983, 1990, 22, 22r, 22re, 91, 94, gap, location, plug, plugs, spark, sparkplug, sparks, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
