22r head trq specs?
Old 01-17-2005, 03:40 PM
terky's Avatar
22r head trq specs?
Hey i am throwing my head back on but i need to know what to torque the head to. Anyways thanks.
Old 01-17-2005, 05:59 PM
Cable Guy's Avatar
Factory spec is 58 ft/lbs but I have seen aftermarket specs as high as 62 ft/lbs.
Old 01-17-2005, 06:36 PM
kyle_22r's Avatar
i didn't wanna monkey around with bolts and stepped up for some ARP studs...i torqued them to 80lbs which makes popping a head gasket less likely. also much, MUCH easier to align the head.
Old 01-18-2005, 10:18 PM
alltrac165's Avatar
58? that's all? Wow, the 22RE is 74 lbs.ft.
Old 01-19-2005, 11:04 AM
kyle_22r's Avatar
same motor...i've never heard of using 74lbs on factory head bolts. i'd be afraid of one going BOOM
Old 01-19-2005, 11:29 AM
PirateFins's Avatar
From the FSM for a 22re
3. INSTALL ROCKER ARM ASSEMBLY
(a) Place the rocker arm assembly over the dowels on the
cylinder head.
(b) Install and tighten the head bolts gradually in three
passes in the sequence shown. Torque the bolts on
the final pass.
Torque: 78N–m (800kgf–cm, 58ft–Ibf).
I think I would stick with that #.
Old 01-19-2005, 09:09 PM
alltrac165's Avatar
:pat: Crap, my bad, that was main caps, not head bolts at 74 lbs.ft. Nevermind me....going back to bed now....
Old 01-19-2005, 09:17 PM
kyle_22r's Avatar
my main caps went on at 85#
...of course, i also went overboard and bought ARP main studs
Old 01-19-2005, 09:20 PM
jimbo74's Avatar
i jsut did the head on my 22r, the torque spec is head bolts @ 58 ft/lbs.... my friends a mechanic and told me to torque them to 75 and i wont have any problems.. i didnt....
bigjstang
08-25-2021 12:41 AM
cars-guy
08-16-2020 06:59 AM
dumpster84
04-30-2016 06:03 AM
Fakayayou
08-09-2015 12:47 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: 22r head trq specs?
