22R-E header
Have been considering this mod for a long time, waiting for my existing exhuast to die, shouldn't be too much longer.
Can you also specifiy what exhaust system you put on your header as well as price and any other deets. So far I would go for the LC Header, but a non LC exhaust due to the cost.
Price? About $50 and some mig wire...
I initially had a NWOR cat-back system when I put the header on, it sucked.
header
I went cheap.. I got a Hedman off of summit racing for $119 but there are things you need to modify on this thing first the colector flange has to be welded to your stock connecting pipe after you cut off the stock Y section then the mounting face of the header to the head has to ground down to be flat so that it will seal since the Head and the welds are different shapes then I have found out the stock shaped o2 sensor will not mount in the flange and also the collector pieces that connect the header to the now welded down pipe have to be reshaped to clear the suspension..:pat:
but it did add power!
David
David
TheBFA
02-15-2020 06:55 AM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
DiggnDeep
09-03-2015 02:45 PM
