| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22r carb help!
#3 (permalink) |
Search for what? "What's that carb part?"
I mean seriously.... Isn't my question(s) a little too nebulus for that? |
#4 (permalink) |
Try Seafoam or other carb/injector cleaner?
Electric choke on these IIRC. When mine started doing that, I just replaced it with a Weber 32/36 and never looked back.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#5 (permalink) |
So is that second butterfly valve supposed to be shut even after warming up?
#6 (permalink) |
No. Only closed on warmup
__________________
Gregg 86 yota extra cab, 4" Pro comp, 33's, cam, header,CF Dual friction, K&N, and so on... (SOLD) 89 toyota 4x4 flatbed MY TRUCK |
#7 (permalink) |
Um, by "on warmup", do you mean while warming up? Or after the truck is warmed up?
#8 (permalink) |
While warming up. On a cold engine after you turn on the key(not cranking yet),you should step on the throttle fully a couple times. That should close the choke fully, then start it up. the truck should run at high idle for maybe 2-5 minutes then kick down automactically, opening the choke butterfly.
Sounds like your choke isn't working correctly.
__________________
#9 (permalink) |
I didn't know they still used carbs on 90's???
__________________
#10 (permalink) |
2wds were available carbed until '90 or '91
on a lot of the carbs, the secondary choke flap stays shut until you mash the throttle. that's why putting on a weber 32/36 often increases performance, since the carb isn't operating at full potential. if your engine is stumbling at constant speed i might check the EGR system to make sure it's functioning properly.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| FS! built 22r, weber carb, holley carb, and camden supercharger | utah | The Classifieds GraveYard | 4 | 05-15-2007 05:27 PM |
| 22r carb troubles | jackedmini | General Vehicle Related Topics (Non Year Related) | 3 | 04-09-2007 07:25 PM |
| 22r carb | Leonardo Muniz | The Classifieds GraveYard | 4 | 01-02-2007 11:08 AM |
| 22r carb | Calvin baxter | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 09-27-2005 11:24 PM |
| 22r carb help. | slimb | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 04-21-2005 04:43 PM |
