22r build question
Old 03-20-2005, 11:16 AM
dr3wstar's Avatar
22r build question
My current 22r in my yota is tierd and im looking at possibly building one up or maybe looking at a supra swap.. but time is an issue since it's my work truck and i need it to make my money..
Are there any 16v sohc or dohc heads available for the 22r? or any that will mate up for a hybrid build? 8 valves is just sad ....
Old 03-20-2005, 11:21 AM
jimbo74's Avatar
you might want to look @ www.engnbldr.com www.doaracing.com www.lcengineering.com
Old 03-20-2005, 11:36 AM
kyle_22r's Avatar
unfortunately there aren't any DOHC heads for our little motors shame, since something like that would give it a lot of extra kick...
might wanna try getting a 22R to build, setting that up and just pulling your current engine and swapping that in to avoid downtime...
Old 03-20-2005, 08:39 PM
dr3wstar's Avatar
thanks for the info
Old 03-21-2005, 07:35 PM
dr3wstar's Avatar
so whats the deal with throwing a 20r head on the 22r? is it a 16v head ?
Old 03-21-2005, 07:38 PM
DudeBud's Avatar
nope it just has smaller combustion cambers and better intake runners than early 22r heads
Old 03-21-2005, 08:00 PM
kyle_22r's Avatar
more of a better modification for a car or 2wd truck. 4wd pickups don't typically rev high enough to take advantage of the 20R head.
Old 03-21-2005, 08:48 PM
dr3wstar's Avatar
i have a std so maybe its something ill look into... any more info or a link would be really helpfull... if im going to rebuild why not go with something that would give me a some extra power!
now is there aftermarket support for the 20r like the 22r? it seams you can pick up a cam and valves/springs for the 22r for very resonable prices... just trying to get the best bang for the buck!
Old 03-21-2005, 08:53 PM
jimbo74's Avatar
the 20r and the 22r are pretty much the same with a few choice differences....
Old 03-22-2005, 02:17 PM
kyle_22r's Avatar
a way to think of it, is that a 20R is exactly the same(compatible) as the 1981 and 1982 22R with the exception of the head and intake manifold being different, and having a larger bore. the other early 22R engines('83-84) had a single timing chain and possibly a different timing cover, but the head should still work. late 22R engines have a taller block and flat top pistons, so you have to have machine work done to the 20R head to use it on these. the head is considered more desirable since it has a smaller combustion chamber. the way the intake ports are designed lets the engine rev higher since they lack the lump in the middle of the port that causes the air/fuel mix to swirl that a 22R has -- gives your gas a straight shot into the cylinder. on the downside, the valves are smaller than those of a 22R and you can't just bolt up an EFI intake like you can with most 22Rs.
20R parts are definitely more expensive since the engine hasn't been produced in 25 years, unlike the 22R which just went out of production in 1995. a rebuild kit for a 20R from engnbldr is $329, early 22R('81-84) is $233, and late 22R('85-95) is $214.
colasurdo
05-14-2022 07:21 AM
cars-guy
08-16-2020 06:59 AM
young buck
18
08-27-2018 02:40 PM
dumpster84
04-30-2016 06:03 AM
thefishguy77
07-30-2015 10:59 AM
Quick Reply: 22r build question
