| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22r/22re swap running poorly
#2 (permalink) |
Come on guy's I need some help here....Please input.
#3 (permalink) |
Did you use a new computer for a 22re? Sounds like a computer/ air flow problem. Anyone else have any ideas?
__________________
--Miles Sold '91 4runner, 22re, 5 spd manual, 180,000 miles, cone filter, Downey 1.5"HD coils, SkyJacker Nitrogens, Magnaflow Exhaust, Stull grill, Clears all around. Check out my sound proofing project and other mods: My 4runner page My 2006 Camry page I'm a Myspace Addict! |
#4 (permalink) |
You might also need to replace your air flow regulator. Not sure about that though.
__________________
#5 (permalink) |
I can tell you the problem right off the bat. It's that Ford fuel pump you're using. You see, at least they circled the problem for you. LOL!
Sounds like an airflow problem to me also. It idles fine, but when you rev it up it suddenly cuts out. Is the TPS adjusted properly? What about the intake tube leading from the AFM to the plenum. Any leaks there? What about the runners? Are all the connectors hooked up to the AFM properly? I had a similar problem with mine (22R) a few months ago and it turned out to be a clogged fuel filter. Did you replace the fuel filter when you put in the new fuel pump? |
#6 (permalink) |
I think it's not liking the open headers. You aren't getting an accurate signal to your O2 sensor like that. When I drove mine like that for a day I had to easy into the throttle or it wound stall.
__________________
-Jesse '92 Pickup SR5 V6 *sold* Downey headers - Flowmaster 40 - drilled rotors - 1" 4crawler body lift - BJ spacers - 33x12.5 AT - OME shocks/stabilizer - Arma bedliner - 35% tint on top of factory - roll bar - Stubbs sliders...one mean mall crawler '99 Chevy S10 Xtreme '96 Jeep Cherokee (wife's) '02 Honda CBR 954rr |
#7 (permalink) |
We did a few thing's as in pulling of the intake tube and see if it would change, so we would know if there were leak's or not..I am using the 22re computer. I havn't checked the fuel filter or or tps, I will probably check that out...I am gonna get that exhaust done tomorrow...Thanks for all the input if you can think of anything else let me know...I will keep you guy's posted.
-Thanks |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22r to 22re swap | JerryD | Pre 84 Trucks | 3 | 02-19-2006 11:13 AM |
| Rebuild or 22R to 22RE swap? | GreeneHoosier | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 08-17-2005 08:08 AM |
| 22RE and 22R Head swap...compatible years? | Mudd Runna | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 04-13-2003 06:53 PM |
| need help (running poorly) | DawzToyz | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 03-13-2003 11:48 PM |
| 22R to 22RE swap | markhodges | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 10-23-2002 10:16 PM |
