22R/20R compression ratio?
Old 03-30-2005, 05:44 PM
1stgenboy's Avatar
Just curious, what does putting the 20R head raise the compresson ratio to?
Old 03-30-2005, 06:23 PM
kyle_22r's Avatar
i think the ratio will bump to about 9.4:1. don't quote me on that though
Old 03-31-2005, 08:33 AM
1stgenboy's Avatar
Thanx for the response. I was hoping for more than that....Does anybody know if you can use pre '85 donut top pistons with the later lazer block and a 20R head?
Old 03-31-2005, 11:11 AM
kyle_22r's Avatar
they won't work too well with the lazer block -- it's 3mm higher than the '81-84 block so they lower part of the pistons won't go all the way to the top.
talk to the guys at LC engineering. i know they can mill 20R heads and do some necessary reworking of an oil passage so you can run the head on a lazer block with flat top pistons -- i think that bumps the compression to over 10:1
Old 03-31-2005, 02:18 PM
Phssthpok's Avatar
I dunno if this will help or not, but this is the most complete listing of 'specs' regarding the 20/22r that I have found (so far.. I'm still searching).
While it doesn't give the specification of the chamber volume for the head, there is a formula about 2/3 down the page that spells out how to work out the EXACT CR you will have with any given set of specifications.
Old 03-31-2005, 03:18 PM
1stgenboy's Avatar
Thanx for the info. I also found a site that states that your compression test #'s should be 17-20 times your compression ratio. This allows for an estimation on CR cause if your compression averages 200psi then that would equal ~10:1 CR. Now if only my bro did not steal my compression tester...doh!
kawazx636
10-06-2021 03:03 PM
live4soccer7
05-11-2016 06:52 PM
Kamaloha
10-16-2015 05:13 PM
dzldust
7
10-06-2015 05:39 AM
Odin
09-26-2015 06:56 PM
Quick Reply: 22R/20R compression ratio?
