2003 ISR Mod Help
2003 ISR Mod Help
I have a 2003 Tacoma Prerunner with the 3.4L V6 engine. I was wondering what I should do about the box pictured with the large black tube coming out of it. Is it a silencer box that should be removed? I know I need to remove the J pipe and the box with the FPR tube coming out of it but I havent seen this other box in any guide. Please tell me if I am correct with everything I have labelled. Thanks.
I didn't remove the box in the 3rd pic.
I'll see if I can find a link for the tubing changes but they're pretty simple.
Christian, <96Runner>, helpe me a lot on that.
I have a write up in the tech section, but the front box may be of a different size. The j-pipe should be the same.
The concept is basically the same. I have to run, but I can help more tomorrow if no one else chimes in.
Dont forget premium fuel!
Okay, here's one
https://www.yotatech.com/forums/show...ght=ISR+plenum
and another (note: mine doesn't look like this... I didn't split any tubes)
https://www.yotatech.com/forums/show...hlight=ISR+mod
and Christian's write-up
https://www.yotatech.com/~corey/tech...r/96runner.htm
It looks the same as the 2002 Pre-Runner....
https://www.yotatech.com/forums/show...threadid=10232
TheBFA
02-15-2020 06:55 AM
voiddweller
53
02-01-2016 05:46 AM
