| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
2003 4runner Limited Rattling Sunroof??
#2 (permalink) |
I believe there is a TSB that covers it. This thread (http://www.toyota-4runner.org/showth...=&threadid=631) tells you how to find them.
__________________
John 2003 SR5 V6 4WD Titanium with cladding Front license plate bracket mod Rear differential breather mod VIN etch on all glass Driver's overhead assist handle Homelink Hilux Surf trash bag mod |
#3 (permalink) |
You know, I had what I would call an intermittent rattle coming from the roof/moonroof area. I never got around to taking it in to the dealer to get it fixed and when I switched to the Dueler A/T 265-70-17 tires, the rattle is GONE!
__________________
Woody "Drive your Dreams" 2003 Dark Blue Mica 4X4 Hilux Surf SSR-G 5VZ-FE V6. My 2003 HILUX Surf Checkout My Truck |Full Leather| |Moon Roof||XREAS| |Rear Torsen LSD| |Mobil 1 Synth Oil| |TRD Sport Oil Filter| |TRD Cat-Back Exhaust||Dueler A/T Revos 265-70-17||THULE/Toyota Lappland 619 Roof Rack/Basket| |Full Husky Liners| |Cee Bailey's Window shades| |Toyota OEM Vent Visors||Griots and Porter "Corey" wax treatment| |Soon: TRD Air Filter|Stay tuned for more...| 2001 Kawasaki 1100 STX DI Jet Ski "With the right vessel, it easy to get a good crew." 1993 Hilux Surf SSR-G "Sold" |
#4 (permalink) |
Guest
Posts: n/a
I had the same problem and it was driving me nuts. I spent hours trying to isolate the problem. The sound seemed to be coming from behind the sunroof mainly behind the driver's side, although I could sometimes hear it on the passenger side as well.
But to make a long story short I found the source of the problem. In the image below you can see a rod running down the outside channel. This rod's purpose is to move the air deflector when you exceed 55 miles per hour and then go below 45 miles per hour. This rod rattles inside that channel because it spans such a long area without any support. If you look back the channel towards the back of the truck you will notice a small black clip which supports this rod. To me Toyota should have put another clip in the middle of this span to prevent this rattling behavior. What I did to fix the problem (at least temporarily) was to fill this channel with a thick silicone grease which prevented the rod from rattling within the channel. This is certainly not a permenant fix but I am still trying to decide what I could use that would isolate the rod from rattling, but still allow it to move forward and back. Hope this helps in your situation and if you have any questions let me know. BTW I bought this up with my dealer and they said they were able to use this solution to fix several 4Runner's which they were unable to fix previously. Hopefully they will pass this on to Toyota so they can make a proper fix to this situation. |
| Tags |
| 03, 2003, 2004, 2005, 4runner, close, fixed, manually, problem, rack, rattle, roof, runner, sunroof, toyota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 2003 4Runner Limited install kit... | cruisinPB | Vehicle Audio & Home Entertainment | 1 | 04-26-2005 07:43 AM |
| How to fix 03 Sunroof Shade rattling? | The Dutch Man | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 12-10-2004 08:49 PM |
| 03 Sunroof rattling fix | WhiteSR5 | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 10-08-2003 09:13 PM |
| several questions about a 2003 4Runner Limited v8 | swspjcd | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 09-25-2003 05:57 PM |
| 2003 4runner Limited | MISTERDRIVER | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 08-13-2002 08:06 PM |
