2002 Tacoma Truck Does Not Reverse
Old 10-28-2014, 06:25 AM
Newby's Avatar
Hello everyone,
I have a 2002 Toyota Tacoma SR5 V6 4x4 Automatic. It runs fine, but it just does not run reverse now. Do you have any idea what's wrong with it?
Old 10-29-2014, 08:03 AM
Newby's Avatar
Originally Posted by Newby
Hello everyone,
Any of you has this problem before?
Old 11-02-2014, 07:48 AM
Junkyard Dog's Avatar
As far as I know, reverse on this tranny is strictly manual, meaning no solenoids are involved. Maybe someone else can confirm this. Hate to say it but sounds like the reverse clutch is out of it.
Old 11-03-2014, 03:50 PM
cep89's Avatar
Check the shifter and linkage. It could be as simple as the retainer failed and the linkage rod has fallen off.
Old 11-04-2014, 09:30 AM
Newby's Avatar
It's an automatic. So do you mean the tranny is out?
Old 11-04-2014, 09:31 AM
Newby's Avatar
How can I check it? Can you explain more detail for me?
Old 11-04-2014, 02:57 PM
cep89's Avatar
Get under it with the engine off,but key on and have someone sit in it and shift into all the gears. Look for a shift linkage that is not moving a lever on the trans all the way into position. Also look for any damage to the shifter or linkage. There should be a retainer clip holding the linkage rod to the lever on the trans, be sure that they are still there and hold the rod on.
duckhead
170
11-13-2017 06:07 AM
vasinvictor
01-20-2016 12:39 PM
camdenbuck
07-07-2015 07:33 AM
PureTacoma_Tundra
PureTacoma_Tundra
06-29-2015 09:45 AM
merc1100sc
06-26-2015 05:24 PM
Quick Reply: 2002 Tacoma Truck Does Not Reverse
