2002 tacoma
Old 04-07-2015, 04:55 PM
wntrhart's Avatar
2002 tacoma
2002 tacoma , wont start, wire from battery corroded. replaced #6 wire to fuse block. turn key you can hear start relay but no dash lights and no turning of the motor. replaced 30amp and 40 amp fuses but still motor wont spin. touch wire from battery directly to fuse block dash lights come on but still motor wont spin . checked neutral safety switch , it is good , had starter checked it is good , no melted wires under dash , replaced ignition switch . still motor wont spin and dash lights stay off . any ideas ?? im at a loss.
Old 04-07-2015, 06:11 PM
rworegon's Avatar
What voltage do you have on the battery?
Welcome to YT!
Old 04-07-2015, 11:48 PM
wyoming9's Avatar
Red face
Welcome !!
If one battery cable was corroded what do the other ones look like??
I would look at the ground cables as well.
Old 04-08-2015, 03:40 AM
wntrhart's Avatar
thanks for reply , checked all the above post. even replaced 30 and 40 amp fuses . replaced ignition switch still no dash lights and no motor spin. starting relay works.
Old 04-11-2015, 10:58 AM
wntrhart's Avatar
found a fuse bolted down inside the fuse block . hidden from view . thanks for your reply!
LCE_Performance
10-01-2015 01:03 PM
bryan34w
12
09-30-2015 02:50 PM
irv
09-29-2015 01:04 PM
charlie_fong
09-27-2015 10:06 PM
Project90
09-24-2015 11:40 PM
Quick Reply: 2002 tacoma
