2001 Tacoma Manual Transmission Grinding
Old 12-02-2007, 01:02 PM
sc4runner4x4's Avatar
My transmission has started to grind when I shift into 2nd and 3rd gear. It happens when I shift up and down. I replaced the trans fluid about 7,000 miles ago with the factory recommended type and bleed the clutch fluid last weekend but it didnt help. Does anyone know what could be the matter?
Old 12-02-2007, 01:06 PM
Adam F's Avatar
Grinding between gears usually means the synchros are going out.
Rebuild is in order.
What did the fluid look like? At all shiny? Particles?
Old 12-03-2007, 11:00 PM
reyflete's Avatar
transmission grinding
My pops transmission did this when he swapped out his clutch and didnt replace the through out bearing just a thought
Old 12-04-2007, 04:57 PM
How much does it cost to have a transmission rebuilt? Thanks for the help.
Old 12-04-2007, 05:23 PM
Adam F's Avatar
http://www.marlincrawler.com/htm/transmission/8a.htm
Old 12-04-2007, 07:46 PM
jjrgr21's Avatar
did it work fine before the oil change?
if so i'd be talking to the person that changed it.
smthwsn357
12-04-2023 02:08 AM
HookahRoo
07-20-2015 07:06 PM
PlayAwhile
07-20-2015 11:36 AM
mengquis
07-13-2015 10:39 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: 2001 Tacoma Manual Transmission Grinding
