2001 tacoma
2001 tacoma
i have a 2001 tacoma 4x4 2.7 4 banger i want to lift it a bit and put bigger tires on it i was thinking something like a 31 inch tire and 3 inch suspension lift will that work on a 4 cylinder what should i do thanks
x2 on using that search thingy! There are countless threads on this subject. You should be able to find out what you want to know.
Just a side note, if your truck came factory with 265/75/16 tires, you already have 32s on it.
Another note, I think if ya lift a taco more than 2in you have to cut one of the crossmembers out. check me on that cause im not sure if its 3in or the 4in kits that require this.
LCE_Performance
10-01-2015 01:03 PM
bryan34w
12
09-30-2015 02:50 PM
charlie_fong
09-27-2015 10:06 PM
