2001 4Runner Light bulbs question ?
Old 02-11-2011, 08:25 PM
rams's Avatar
Hey guys, So i'm going to change my my front bulbs to a brighter whiter color.
HeadLights: 9003ST Silverstar High Performance
Fog Lights: H3ST Silverstar High Performance
Now my question is, which do i get for my corner lights? i know the bulb size is 2825. But they dont have that in the silverstar collection.
I am going to install clear corner like these:
Anyone know which bulb i can use inside here?
I would like one that is the same brightness as the Headlights and Fog lights. They have a temperature color of ~4000K (white)
Thanks for the help guys.
Old 02-11-2011, 09:20 PM
Elton's Avatar
id just go with a 921 bulb a little bigger but it will be slightly whiter than the 194
Old 02-17-2011, 12:54 PM
toYAUta's Avatar
I just put LED bulbs in my front corners and they are bright. 12 diode LED bulbs.
I also used LED's for the licence plate. 4 diode LED bulbs.
Old 02-17-2011, 03:34 PM
rams's Avatar
cool LED.
But till the LED's be brighter than the Silverstar bulbs?
Old 02-17-2011, 04:29 PM
pdyebrasil's Avatar
If you go with LEDs, you are going to have a killer time finding one that matches your headlight color.
Most white LEDs run around 6000k, which has a slight blue tinge to it. Even the "warm white" LEDs will be too "cool" to match your headlights.
Make no mistake about it, I LOVE LEDs. I don't have one incandescent bulb on my 4Runner (they're all either LED or HID). It just took me a long time to find a white LED that would match even my 5000k HIDs.
In the end, I just put amber LEDs in my clear corners until I found a decent white LED that matched. My advice is to just use a standard white (clear) incandescent bulb.
Good luck!
Old 02-17-2011, 05:08 PM
Elton's Avatar
if all else fails just get some amber colored ones
Old 02-24-2011, 01:57 PM
rams's Avatar
ok i found these here:
http://www.svetila.com/en/light-bulb...blue-3210.html
can i use these? it says it has 4000k temp color...but it says its blue ... ?? i though 4000k was white? any thoughts?
Old 02-24-2011, 03:56 PM
pdyebrasil's Avatar
I found this nifty little chart for ya...
So those bulbs should match pretty well. I will say that a pure white color is actually closer to 5000k, so even the Silverstar Ultras will look kinda yellow. I have 5000k HIDs and they make even standard (4300k) HIDs look yellow. Check out the kelvin scale:
Old 02-27-2011, 07:56 PM
rams's Avatar
Thanks a bunch
i think i'll go with those then.
but any thoughts why in that site it says the bulb is blue? if its only 4000k? lol
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Avenged
07-09-2015 07:55 AM
colinmil
07-06-2015 04:03 PM
Quick Reply: 2001 4Runner Light bulbs question ?
