2000 4Runner Upper Ball Joints R&R?
Old 07-08-2014, 08:31 AM
mudmaster's Avatar
Anyone done this? Do I need to bring the knuckle in to have the joints R&R or can I do it myself?
Old 07-08-2014, 10:15 AM
Jomoka's Avatar
You can free-rent a ball joint press at AutoZone, but be assured that it's still a pretty tough job. After being in there for 15-ish years, they really, really don't want to come out.
Old 07-08-2014, 10:21 AM
mudmaster's Avatar
That's what I'm thinking too.
Old 07-08-2014, 05:52 PM
rworegon's Avatar
mudmaster, where was the pic in your avatar taken at? Just curious.
If I do mine ever again, I just may consider buying the Toyota UBJs and have a local shop replace them after pulling the knuckle. As Jomoka says, they don't want to come out easily in most cases.
Old 07-09-2014, 05:30 AM
mudmaster's Avatar
That was taken at Evans Creek ORV park in Washington.
Old 07-14-2014, 11:03 AM
mudmaster's Avatar
Left side is put back together, right side is apart and I'll start putting back it together tomorrow. I'm doing the Tundra brake upgrade also. I was able to use a BFH to get the upper BJs out. Right side fought me hard.
Old 07-15-2014, 01:43 PM
wyoming9's Avatar
Red face
I just did mine on my 92 4Runner a nice little OTC tool popped them out with very little effort.
Getting them out was about the easiest part of the whole job.
Old 07-15-2014, 04:14 PM
Jomoka's Avatar
Googling for a pic I can see that you got to miss the hardest part with your second gen - since the ball joint uses bolts on the 'big' side. On the 3rd gen, the big side is pressed into a hole in the cast wheel carrier/upright. Getting the tapered ball joint out of the hole is the easy part, pressing the ball joint out of the carrier is a much larger struggle.
Old 07-15-2014, 11:05 PM
wyoming9's Avatar
Red face
The 2000 Tacoma is the next to get done
Old 07-16-2014, 05:40 AM
mudmaster's Avatar
Exactly!
mskalmus
05-28-2017 07:51 AM
09-04-2015 09:27 AM
Avenged
07-09-2015 07:55 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 2000 4Runner Upper Ball Joints R&R?
