2000 4runner under dash wiring
Was having trouble with a P1780 trouble code (the tranny was not shifting out of 1st while in DRIVE. Tranny tested out fine and is in good condition)...initially replaced the Neutral Safety Switch but that did not solve the problem. Turns out I need a whole new under dash wiring cluster/harness. How interchangeable are the dash wiring systems compatible with one another in the 4runner 3rd generation series? I have a 2000 4runner 4x4 automatic, so do I need an identical year wiring harness or can I use another year model, such as a 98-99-2001?
Thanks for the info, LUCKILY, I was able to find an identical year replacement cluster and got it installed.... took a hit to the wallet. Ur I'm back on the road again!! Just really quick, would you happen to know if a '99 4Runner frame will work on a '00 4Runner cab?? My '00 has rust problems so I'm looking to swap out the frame....
