2000 4runner transmission prob with video.
1st post.Thanks for the great forum ,has helped me many times.
My transmission was replaced with a used tranny that had 80,000 miles,for $1500 at 160,000 miles. Radiator trans cooler mixed with trans fluid at around 170,000 miles. I flushed filled 3 times. 1 month ago the transmission started to not wanna down shift to first at a stop. I flush/ filled trans and it work fine for a month. Now it,s doing it again. My research leads me to think it,s wanna the solenoid in the trans. Can any1 give me links to the info about them.which 1,how to,info,ect.
vid of 200,000 mile 4runner
http://youtu.be/mzxEW0ktex8
huge thanks
I found this,He,s having the same prob. Looks like he never got a good answer?
thanks
https://www.yotatech.com/forums/f2/2...opping-231490/
Local parts store said that there computer only showed 1 part #.
Local toy dealer said there were 3,,two being the same. any ideas of part #,s? there price was 700+ for the 3.
huge thanks
thanks
or these
or these
http://www.bulkpart.com/Merchant2/me...e=A340solenoid
any advice would be great, I wanna get some on the way.
thanks
I,ll try to get vid of trans f/ing up today.
thanks
got video of it messing up
Vid of what the trans is doing. Got it to happen a few times in a row.
http://youtu.be/kGTHTnyq6Sw
Please help
thanks
also
noticed that the gear indicator on the dash lights up green in p/r/n/2/1,but not drive!
could that be a clue?
seems this guy had a bulb out,not related?
https://www.yotatech.com/forums/f131...-drive-209206/
any1?
Please help
thanks
also
any1?
dump fluid
Was thinking about draining the trans fluid and refilling to see if that clears up the issue again. 'think it,s a waste of fluid and time?
Are there any more details or vids I can post to help figure out whats going on with my tranny?
Any1
Proud owner of 2000 4runner with 198,000 miles. (parts replaced so far exhaust twice,fuel filter,power packs and wires plugs twice,used trans,radiator,belt every 70.000,starter.) (wanna join the 200,000 mile club) and2003 4runner with 167.000. nothing broke on it. Bought both brand new.
please help
thanks
Any1
please help
thanks
changed
thanks,no lights yet
Just changed. looked new. Auto parts store says it takes 2 quarts. More like 6!
but whatever
I,ll test and get back.
To drain really good I start and run through gears a few times. Then stop and repeat. gets like another 2 quarts out.
but whatever
The clutch packs may be gone then thanks to the coolant mixing with the ATF. If that is the case (take it to a pro), look for another tranny (that seems what the video indicated IMHO).
BigballsMcfalls had similar problems with the milkshake and his tranny finally died.
clutchless manual
Took it around town. Still doing the same as in video.
It,s not slipping! If i put it in 1st at a stop then drive it works perfect.
What trans is doing in vid appears to be that it,s either staying in 2nd or 3rd.
Have been driving it like a clutchless manual transmission. works good. just a huge pain.
Any1 know about those soleniods from above?
thanks
thanks
One water get in a trans it's "game over".
You can't fix it by changing the fluid.
-John
IPT Performance Transmissions
Facebook- IPT Performance Transmissions
IPT Transmissions YouTube Channel
IPT Performance Trans Blog
-John
madxman21
07-09-2015 10:26 AM
Jnkml
07-06-2015 01:20 PM
