Old 03-31-2016, 08:16 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Specifications & General Maintenance
Print Wikipost
2000 4runner - maintenance schedule
Old 06-10-2009, 01:55 PM
maguirre's Avatar
Hi all,
I have a 2000 4Runner, 5spd SR5, which I bought in 2004 with approx. 70XXX miles. I remember taking the truck to Toyota for "servicing" right after I bought it. I have no idea what they actually did with the car. Ever since, I've been pretty good with changing the oil/oil filter, but I haven't done anything else.
This summer I was thinking of checking/replacing certain things in the car so I come to you guys for advice.
Some of the things that come to mind are:
timing belt
spark plugs
spark plug cables
serpentine belt/s
water pump
coolant fluid
fuel pump
tranny oil
differential oil
My car now has about 85XXX miles on it. Please let me know if I should replace/inspect any of the items mentioned above. Is there anything else I should be looking at???
Also, please point me to any write-up that covers this subject. I'm currently searching for any info relating to this.
tia,
maguirre
Old 06-10-2009, 04:40 PM
cosmophonic12's Avatar
fuel filter
new PCV valve
clean/inspect mass airflow sensor
clean throttle body
clean/inspect battery terminals
rear/front differential oil
transfer case oil
transmission change
seafoam
grease drive line
Old 06-10-2009, 04:46 PM
GhostriderTx's Avatar
Did you mean fuel filter or fuel pump? I have done pretyy much everything listed on my 01 with 81xxx miles except the fuel pump. For some reason I thought it was in the fuel tank and a real pain to get to. I would add = change power steering fluid.
Old 06-11-2009, 06:35 AM
maguirre's Avatar
yeah,... I meant fuel filter... sorry.
so you guys are saying I should take care of everything I listed plus what Cosmophonic12 added???
thanks,
maguirre
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Avenged
07-09-2015 07:55 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 2000 4runner - maintenance schedule
