2000 4Runner Harmonic Vibration
Old 06-29-2009, 07:23 PM
dollarman69's Avatar
I have a 2000 v6 2wd 4Runner with 112,000 miles. It all of a sudden developed a vibration between 60-70mph. I checked the U-joints, and the front was bad, so I replaced them both. I drove it, but the problem was still there. I noticed that I was at 1800rpm when the vibration occurred. I parked it in my shop, and ran her up to 1800rpm, and the same vibration was there. I checked motor mounts,and did not see any obvious problems. I checked all of the exhaust mount, as I have heard of this causing harmonics issues, but all are in tact. Anyone have any ideas, or any experience with this problem?
Old 06-29-2009, 10:46 PM
scuba's Avatar
IMO you should have just replace ALL u's while you had the shaft out.
did you check the tranny mounts? crossmember bolts to make sure they are tight..?
Tires and wheels balanced ?
Just a couple ideas there
Good luck
Old 06-30-2009, 08:03 AM
Ardent's Avatar
I'm going to not go with tires.
Old 06-30-2009, 01:39 PM
I appreciate the drivetrain and tire suggestions, but the post says I replaced BOTH joints, and later pulled it in the shop and ran up to 1800rpm, and vibration was still there. Tires and drivetrain mounts don't come into play in PARK, and my shop ain't nowhere big enough to get up to 60mph inside !!
Any other ideas?
Old 06-30-2009, 01:44 PM
Any other ideas?
Old 06-30-2009, 06:39 PM
b18vteceg's Avatar
in fairness everyone is trying to help.....drivetrain still has moving parts when in park.....for example tranny gears and the torque converter still move even when in park. but i dont think that's the issue
is this a possible misfire? maybe when you get to a certain rpm the spark is igniting the fuel?
or is the vibration much worse? if you think its the crank pulley pull it off and start the motor with no pulleys or belts and see if the problem is still there....
i would say if its not a misfire and all mounts and look good....crank pulley is a good place to start.
Old 07-01-2009, 08:43 AM
mt_goat's Avatar
I wouldn't run the engine with the crank bolt off... or loose for that matter.
More info on that:
http://www.motor.com/MAGAZINE/Articles/012007_04.html
Quote from abouve link:
....on the 5VZFE, the crank sprocket and harmonic balancer share the same woodruff key. Plus, the crank sprocket just slips onto the end of the crankshaft. Some techs believe that this arrangement of slip-fit sprocket and single woodruff key make it extra important to cinch that harmonic balancer securely in place
Old 07-01-2009, 12:38 PM
b18vteceg's Avatar
i agree...
but if he has checked everything else out....and thinks its the crank pulley....its not like he has to run the motor forever.....and it beats spending over 300 on a crank pulley if thats not the problem....
id still look into misfiring first.....
mskalmus
05-28-2017 07:51 AM
Avenged
07-09-2015 07:55 AM
Cplmike
07-08-2015 08:47 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 2000 4Runner Harmonic Vibration
