2" lift on a 2002 4Runner
Old 09-14-2007, 06:55 AM
Atwater27's Avatar
I bought a 02 4Runner last month and am looking for an inexpensive way to lift it about 2". I had a 94 before this and installed the downey rear coils and that was the best thing I could have done to it. I did a lot of reading on this website and it seems this might be a little more difficult than that was. I was hoping to firm up the ride up a little also. Not planning on doing much offroad but will be using it to pull the boat from time to time. The 2 options that I keep comming across is the Performance Products 2" springs and the 99 coils. If I get the 99 coils from a private party how can I tell if they are the tall 99's? I was hoping on keeping the same shocks at this time and replacing them later. Does anyone know of any good shops in the Minneapolis area that can or would do this kind of work?
Thanks
Craig
Old 09-14-2007, 07:05 AM
netwt12's Avatar
http://www.wheelersoffroad.com/96024rundstrlift.htm
daystar 2.5" $249.95
Old 09-14-2007, 07:13 AM
frodin1's Avatar
The next step up would be to do the Tundra/Ome lift. But if you can't do the work yourself it's going to cost you. I found all the components and did it myself for about $500.
Old 09-14-2007, 07:34 AM
Simon's Avatar
I was going to mention the tundra/ome lift as well. I've had it on for more than a year now and I love it.
-Simon
Old 09-14-2007, 08:27 AM
emptypockets's Avatar
I would suggest staying away from the coil spring spacer kits. They're cheaper in the short run, but eventually will make your stock springs sag (personal experience speaking). The Tundra/OME is a great setup, also check out the Sonoran Steel site and the 7.1 kit. There are some options out there, but don't go the spacer route...do it right the first time with a coil spring lift.
Old 09-14-2007, 08:37 AM
Rock Slide's Avatar
x2. I'm not a big fan of spacer lifts either...spacers only lift your current old/worn out springs. To me, that's not really an improvement. I went with the SS 7.1 lift kit as Empty mentioned. Not as cheap as a spacer lift, but a much better lift kit IMO.
Old 09-14-2007, 09:30 AM
Atwater27's Avatar
What about the Toytec OME 3" Lift? The SS 7.1 looks good but more than I wanted to spend. If I went with the Tundra/ome lift would I go to the dealer and get the Tundra coils and then to the web for the OME? or is it sold as a kit?
Thanks Craig
Old 09-14-2007, 10:08 AM
Rock Slide's Avatar
Thanks Craig
A few guys are running the toytec lift...maybe they can comment on that one.
As far as the Tundra/OME lift, yes it can be pieced together (as long as you know what to get) or you can buy it from Steve as a kit.
Old 09-14-2007, 10:13 AM
waskillywabbit's Avatar
We have some lifts for your vehicle.
Old 09-14-2007, 04:50 PM
Sloan's Avatar
to bad the 7.1 kit is only for 4WD models..
Old 09-15-2007, 07:19 AM
If you are wanting about a 2" lift, I went with a ToyTec lift. See sig for options. I went with a softer ride since I'm not pulling anything in the forseeable future. But you can opt for a stiffer suspension in the rear.
Not sure if the ToyTec options I went with are in your budget but on my 2002 ride I got about 2" of lift.
06-01-2021 01:51 PM
Road Bull
10-10-2015 04:55 PM
09-04-2015 09:27 AM
akaphilly
07-09-2015 02:18 PM
God's Bounty Hunter
07-08-2015 12:54 PM
Quick Reply: 2" lift on a 2002 4Runner
