2" bodylift in
Old 03-17-2004, 02:33 PM
Jackpot2's Avatar
2" bodylift in
I put my 2" Mr. R Brown bodylift in today on my 2nd gen surf and all went as it probably should. I had the bottom end of the steering linkage loose b4 I did anything. I did notice though that the steering shaft needed opening at the top end and not the bottom and it extended as soon as I had done this ... then things got tight again and when I loosened the top even more and reloosened the bottom end again it extended too. Even after all was lowered back down as it should the rag joint bushing still looks a bit too wavey for my liking. Otherwise all is rosey in the garden
Old 03-18-2004, 04:50 AM
delboy's Avatar
Talking
Bet it looks silly with a 2" lift and those little tyres.
Old 03-18-2004, 08:36 AM
Waterboy's Avatar
Got any pictures? I always like checking out over seas Toyota's.
Old 03-18-2004, 08:37 AM
mastacox's Avatar
Is that where you're trying to drive in your picture?
Old 03-18-2004, 09:58 AM
Waterboy's Avatar
I never thought about it that way.
Old 03-18-2004, 01:03 PM
Jackpot2's Avatar
This is before I did it, I took the pic in front of the cabin specially coz its good for before and after pics...
and this is all I can show you (unless you want grizly detail) of what happened yesterday
(and Delboy try some iron in you next time you try to tighten your crank pulley on)
Old 03-20-2004, 12:43 PM
delboy's Avatar
(and Delboy try some iron in you next time you try to tighten your crank pulley on)[/QUOTE]
Ooh! Saucer of milk!
bobjohnson2121
09-17-2015 08:07 AM
justinking060310
09-06-2007 04:16 PM
Twisty
05-04-2006 11:01 PM
4Hummer
12-15-2004 01:20 PM
4Hummer
12-12-2004 07:00 AM
Quick Reply: 2" bodylift in
