2.7L Exhaust/Header/Cat/Test Pipe
I will be purchasing a new LC header for my 2.7L Toyota 4runner in the upcoming week but am running into the problem of having my head pipe connecting directly to the front of the cat. Being that its a royal pain in the a$$ to saw it off and weld a flange on the front, I'm looking at the alternative of just replacing it (the cat).
I rather not pay the 160 bucks for a new free-flow from LC and am looking at maybe just picking up a tacoma cat instead, I'm guessing the application is virtually the same if I get a cat for a regular cab, short bed taco? Anybody know?
Also, LC has whats called a "test pipe", and from the looks of it its just a bypass of the cat all together. I'm not in Cali, or anywhere that does emission inspections so I'm wondering if anyone has any experience with these....
Something is wrong with LC's online catalog but I'll post up links to the products tomorrow assuming its fixed!
Thanks guys!!!
Kyle
Thanks guys!!!
Kyle
-Will
after the header put a magnaflow or carsound cat for like $60 bucks and that should work just ditch the stock manifold and cat
You are correct with regard to the test pipe - all it is a straight piece of pipe that fits where the cat would usually go. In order for your test pipe to not throw a Check Engine Light, you need to be sure to install a "mechanical CEL fix" or "mechanical o2 fix." So long as you are not throwing any codes, you will free up a bit of horsepower and have a save a few pounds! By ridding yourself of the cat.
-Will
-Will
They say that "test pipe" is not street legal but I'm guessing it should be fine given I have no emissions checks, besides I could just use this to buy me some time so I could get an actually flange welded to my old cat...
Again, wouldn't you think a tacoma cat would work the same? It seems to be hard to find a stand alone cat (w/flange) for 4runners with the 2.7L since the head pipe and cat are all one piece. I guess ppl think why the hell would you ever accessorize a 2.7L 4cyl....!! .....haha...I do
kawazx636
10-06-2021 03:03 PM
hiluxinargentina
09-30-2015 05:51 PM
jacked_72
09-14-2015 03:31 PM
