2.7 3rz timing chain
Does it run , the only real way is by the sound of it when it is turning over to start . If it does run ,is there any loss of power . One guy put a piece of paper over the exhaust pipe but I don't know how to determine it that way but the those motors ain't real bad for jumping time.
Very good poss it is out but I don't know that you could have really done it by hand ? Are you sure it was in time when the tensioner was out ? During assembly? But if there is nothing external stopping it from turning the that's what it is . I really hope u didn't warp a valve ,cause I have done it just like you did before .
I found the problem bolt was keeping it from turning and cam was hitting it and getting stuck is it hard to make it jump timing with a wrench and socket
Sent from my DROID RAZR using YotaTech
Timing looks right when I get time I'm gonna pull off pully and see if keyway is straight up to number 1 cyl but on tdc can marks is straight up to the block cause motor sits crocked in truck
09-04-2015 09:27 AM
