2.2" pulley folks w/ 7th injector?
Old 07-20-2006, 07:00 PM
QSVeilside's Avatar
Just want to figure out if the 7th injector can run the 2.2" pulley without further fuel modification, ie. 190 LPH Walbro upgrade.
Just thought I'd ask if anyone has tried it. I know of one member that has the 7th injector with 190LPH fuel pump, and even with the 2.2" pulley, was running too rich. Perhaps an AIC timing control unit might be sufficient for folks with the 7th injector to run the smaller pulley.
Old 07-20-2006, 07:05 PM
mastacox's Avatar
As-is, the 7th injector does only a so-so job of fixing the lean-out problems... To run the 2.2" pulley you might consider the URD 7th injector upgrade kit as well.
Blamalam
03-12-2022 07:34 AM
Marsheen
02-17-2016 12:29 PM
Obmi
11-24-2015 11:37 AM
moparbay
10-06-2015 09:24 AM
craismith1
7
08-27-2008 01:43 PM
Quick Reply: 2.2" pulley folks w/ 7th injector?
