1st.gen, rear window solution
Old 12-29-2003, 07:45 PM
4runnerx4's Avatar
Just a post for those who might have this problem. If you have a 1st Gen. 4 runner and the rear window will not work. I found the first thing to look at before you replace any of the ( it seems like 1000 relays/switches) to replace or check. Pull your panal cover off the drivers side to get at the main relay and wiggled the harness while pushing the up/down switch. I discoverd after getting all new relays/switches accept the main relay and a few cuts and scratches that when i went to replace my main relay( with a salvage yard replacement) i plugged in the replacement above the original pulling the harness up to reach the connection and the window worked so (2+2=4) i plugged it back into the original relay and wiggled the harness back and forth while holding the switch and wala! Poor conection problem! So save yourself some headaches and dollars and check this first.
06-01-2021 01:51 PM
jasonty
41
12-23-2018 01:00 PM
sabine
07-18-2015 03:59 PM
icentropy
07-14-2015 10:23 AM
coryc85
07-06-2015 04:07 AM
Quick Reply: 1st.gen, rear window solution
