1st gen deckplate mod
Old 07-06-2003, 06:15 PM
4BangR's Avatar
I was just wondering if I can do the deckplate mod on my1st gen pickup w/ 22RE. Seems to be a dumb question, but I can't find any on the mod page. Appears to be about the same procedure as the newer models. Jus' checkin 'fore I start cuttin'.
Old 07-06-2003, 06:55 PM
doink's Avatar
i would say it depends on what shape your airbox is. if its square/rectangle looking like the 3rd gen. 4runner, im sure you could. even if its not, i bet you could still think of some way around that
Old 07-06-2003, 07:35 PM
Erich_870's Avatar
I looked at doing it to my 1st gen, but I couldn't find a large enough flat surface to attach it to. Let us know if you figure something out.
Old 07-06-2003, 07:55 PM
ewarnerusa's Avatar
doesn't have to be flat
I don't think the surface should have to be flat. You could cut the hole and seal some PVC pipe inside it. PVC comes in all kinds of diameter end pieces with threaded caps to plug up the intake. The deckplate is just ideal (I think) because it seals back up almost flush and it looks cool. PVC plugs should be just as water tight. Get creative.
Old 07-06-2003, 09:51 PM
Erich_870's Avatar
That is a good point. I guess I had just assumed you had to use a deckplate. I will check my air box out again. It might be a couple smaller pipe fittings would work well. Thanks for the idea
Old 07-07-2003, 06:42 AM
ewarnerusa's Avatar
Check this link out, http://www.customtacos.com/tech/arti...4/intakepart1/, for some ideas. I realize it is on a newer style airbox. I was running along these thoughts for a while before I stuck with the good ol' deckplate.
Old 07-07-2003, 07:09 AM
4BangR's Avatar
Thanks for the ideas guys. I will have to wait a couple days to look at my airbox because its at a muffler shop so they can weld up a new exhaust system.
suppra87
07-15-2021 05:15 PM
punks_is_4x4
05-31-2016 06:03 AM
Badfish740
09-04-2015 04:21 AM
dlaiben
3.4 Swaps
09-03-2015 09:57 AM
vanion2
07-29-2015 06:17 PM
Quick Reply: 1st gen deckplate mod
