1st Gen 4Runner Help
Old 12-30-2003, 12:17 PM
kwando's Avatar
Question 1st Gen 4Runner Help
My driver side vent glass was broken the other day by someone with a rock, talk about holiday spirit! I need some help on changing the glass out.
Toyota sells the single panes of glass but my problem is I can't seem to find out how to get the frame out to put the glass in. I have an illustration from Toyota that shows several bolts folding the frame on from inside of the cabin, but those bolts are no where to be found. The only bolts that i have access to are the ones for the top.
Any help is appreciated.
Thanks in advance.
Simon
Old 12-30-2003, 01:15 PM
Plays_with_Toys's Avatar
Are you talking about the small triangle just infront of the main window on the door? Mine has a couple screws that hold the glass in place, isn't that all you'd have to take out to replace the glass? Maybe runners are different that the pickups
Old 12-30-2003, 01:42 PM
4runnerx4's Avatar
window help
If it's like my 87 you should be able to take out the one screw at the hinge point,clean out the track and slide the new piece in!
Old 12-30-2003, 02:05 PM
kwando's Avatar
No the glass i am referring to is beind the driver side glass on the top. The glass slides back and fourth.
See the following pics.
Thanks again.
Old 01-03-2004, 08:22 PM
4runnerx4's Avatar
glass
OK, now that i know which glass it is. i pulled the glass out of an extra top that i had and this is how you do it. First you have to remove your inside trim then using a sharp scraper you have to cut the seal(butyl tape according to the yota manual) and then push and pry the entire window assembley out. Then you will gain access to the screws that hold the window molding and the center frame.If you dont have an original yota manual and not familiar with glass installation i'd take it and have it done because it's alot like a front windshield where you have to replace the seal to stick it back in the top! Hope this helps!
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
coryc85
07-06-2015 04:07 AM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 1st Gen 4Runner Help
