1999 Tacoma Rear End Noise
Old 06-24-2009, 07:03 AM
bholb2's Avatar
I have a 1999 V6 4x4 Tacoma. The rear end has began to make a grinding noise. It first began only when in 5th gear. If you would let off the gas, the noise would go away... If I gave the truck a lot of gas it would go away... It would only make the noise when the gas pedal was slightly pushed in. After a couple of days, the truck started vibrating after about 30 mph???? Any ideas..????
Old 06-24-2009, 11:49 AM
Doddy's Avatar
Possibly a bad ring and pinion.
Old 06-24-2009, 12:19 PM
swapped89's Avatar
or u-joints- axle bearings
Old 06-25-2009, 05:58 AM
bholb2's Avatar
The garage said it was a bad pinion bearing, along with a bad rear u-joint. Sound pretty feasable?
mskalmus
05-28-2017 07:51 AM
MTLroadierunner
07-15-2015 12:58 PM
Gamble_STi
07-07-2015 07:54 PM
MTLroadierunner
07-06-2015 12:17 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: 1999 Tacoma Rear End Noise
