Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
1998 toyota 4runner wont start...Need help
#2 (permalink) | |
Personal
Sales Rating: (0)
Quote:
__________________
97' 4RUNNER SR5 4x4 Lift:OME 881's OME Fronts w/ TOYTEC top out spacer, Billy 5150's and LC Rears 2in. 4crawler BL, SS Diff drop, Custom welded drop bar Performance:Yellow Top,Custom Dual Vortex Exhaust, Magnaflow Hi-flo CAT, K&N FIPK, Diff Breather Mod Wheels & Tires:315 16x9's on MOTO METALS Lights:Silver Reverse Glow Gauges, Hella 500's Armor:Trailgear Sliders, Taco ARB "Sounds stupid. . .sign me up!" |
#3 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
#4 (permalink) |
Personal
Sales Rating: (0)
Mine did this once as well, it turns out it was a bad ground from the battery.
Re-check all your connections well! How many miles do you have on this beast?
__________________
2004 Toyota Tacoma 4x4 Xcab 3.4L w/ Diff Locker. Mostly stock for now.... |
#5 (permalink) |
Personal
Sales Rating: (0)
I'd say you need to look at your fuel system. The cranks and turns over so I wouldn't worry about a bad battery or bad battery connection. Get an wiring diagram and starting checking the electrical circuit for your fuel pump, if your not getting fuel like you say.
__________________
98 4Runner SR5, 4x4, Stock suspension/drivetrain, E-Cooling Fan Mod, B&M Trans Cooler, Alpine CDA-9887, Boston SX60, Polk Audio db651s, Linear Power 4503, Brown Bread sound deadening throughout... |
#6 (permalink) |
Personal
Sales Rating: (0)
[OP]
the truck has 128,ooo miles. I am getting fuel at the block so some sort of electrical thing is causing this problem im guessing.
#7 (permalink) |
Personal
Sales Rating: (0)
Sounds like maybe a starter problem? Try banging on it a few times and then try to turn her. You may have bad contacts on the starter that need to be replaced (Toyota sells a starter repair kit that contains the necessary items).
#8 (permalink) |
Personal
Sales Rating: (0)
Bluemarlin:
Have you checked your spark plugs, wires, etc? What about your oil and coolant? Hopefully there is no mixture there. (head gasket problem from overheating). Id also run a compression test if you have one. Any open vacuum lines? Definetly check the easy stuff first. I'm no mechanic, but, you may want to call one or bring it down to get looked at if you really need the truck ASAP.
__________________
1997 4x4 Limited 4Runner 3.4L - ARB Tacoma Bumper, Icon's, OME 890's, FZJ-80 Wheels, E-Locker, 285/75/R16 BFG KO's. 1996 4x4 3.4L SR5 4Runner -- SOLD 6" IFS lift * Front: Tundra TRD Coils/Bilstein 5125 * Rear: FJ80 Shocks/Coils * ARB Bull Bar + Warn M8000 * 35" MTR's * HID's * OBA * E-locked! |
#9 (permalink) |
Personal
Sales Rating: (0)
What was the fuel pressure on the rail? Just because it had fuel there doesn't mean it had enough psi to run. Could have toasted the fuel pump. I have heard about the clutch safety switch wigging out also it is worth checking into.
__________________
00' Taco | ARB Bull Bar | Warn XD9000 | KC's | Fabtech adjustable coil overs | Rear diff Mod | 16" Classic II Rims | Total Chaos Spindel Gussets U chicken or whut? |
#10 (permalink) |
Personal
Sales Rating: (0)
It wouldn't be the clutch safety switch, because if the clutch pedal is not fully depressed or the switch is bad, it won't even crank.
Definitely check your ignition system and other electrical components. |
#11 (permalink) |
Personal
Sales Rating: (0)
Didnt I already asnwer this in thumpertalk?
__________________
Toyota Master Diagnostic Technician "MDT" 2010 Ram 2500 Cummins 6 spd 2003 Toyota Highlander 4WD 2006 Toyota Tercel 2DR 2007 KTM 105SX 2007 KTM 85SX 19/16 2006 KTM 300XC-W 2002 Yamaha TTR 125L 2002 Kawasaki KLR650 2002 Suzuki Eiger 400 4WD Licensed "Amateur Extra" Class Ham Radio Operator |
#12 (permalink) |
Personal
Sales Rating: (0)
[OP]
yes, yes you did. Im starting to think that maybe the crank position sensor died.
#13 (permalink) |
Personal
Sales Rating: (0)
[OP]
update I need some help. I bought a code reader because no shops here rent them.
I pulled p0100 and p0110. What should I check for? Apparently this is an MAF code. Could this keep the truck from running? |
#14 (permalink) |
Personal
Sales Rating: (0)
Has it started? My buddies tacoma did something similar, drove it to school, ran fine, we came back out and turned over but wouldnt fire, tried a million times. Anyways on last resort we rolled started it, it started right up and ran perfect, took it to our buddies shop, they determined it was crank position sensor even though it wasnt throwing the code...
__________________
98' Tacoma 4x4 2.7 5spd *Pacer rims *Toyo 31's *Pioneer system |
#15 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
#16 (permalink) | |
Personal
Sales Rating: (0)
Quote:
You said you have an alarm on it. i'd go after that & the CEL for the MAF first since you say you have fuel, and the batt isn't bad, and it's cranking, so the starter's doing it's job. Pull a plug, or atleast a coil, and ensure that you have spark(let it ground to something, you'll see the ark while cranking). i'm willing to bet it's something with that gosh darn alarm of yours ;-) :-P You'd be amazed at how many times i've seen batteries go dead in vehicles, replace the battery, and the vehicle not start afterwords, cuz the stoopid alarm reset into "retarded problematic alarm mode" instead of "protect the vehicle mode"!! :-P Remember, every engine needs fuel, air, spark, timing, to run/operate(which branches out into many other areas from there). Remember those basics and by ruling out each one you will almost always find the problem. Good luck, hope you get it running again soon.
__________________
90 4Runner 5spd V6 4x4 = blown motor. Result = 350sbc, TH400, NP203 IN AND RUNNING. Last edited by Anubiscougar; 05-08-2008 at 08:11 PM. |
#17 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
| Tags |
| 1997, 1998, 27, 4runner, alarm, battery, charged, crank, cranks, forerunner, problem, reset, runner, start, starting, toyota, wont |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 85 toyota 4x4 wont start | yotafeind | 84-85 Trucks & 4Runners | 21 | 02-18-2007 11:38 AM |
| help!!! 4runner wont start | ichoc2 | 86-95 Trucks & 4Runners | 6 | 06-14-2006 02:32 PM |
| 1998 4Runner won't start sometimes | Bird333 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 09-29-2005 09:52 AM |
| 4runner wont start | doink | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 10-01-2004 06:28 PM |
