1998 4Runner... What wire under the fash is for parking lights?
1998 4Runner... What wire under the dash is for parking lights?
A friend of mine is hooking up white gauges and needs to tap the parking light wire so the gauges turn on with parking lights, etc.
Anyone know or have a pic of that wire? Color? If not, we have to run it to a corner light up front. He is trying not to do that.
Thanks,
Thanks,
Thanks,
Thanks,
http://community.webshots.com/photo/...33016800BVbOOj
Originally Posted by WT
Mines a 96 but would think the color code is close or if not you could use a trusty meter to be sure I tapped into the wire off the dimmer switch "green with silver strips" comes on only when the dash light are on.
If you need the parking lights, they are green (+) at the 13 Pin Connector on Back of Fuse Panel:
http://www.the12volt.com/installbay/...942&type=Alarm
BeMiceElf
10-10-2015 09:40 PM
Johntom240
7
07-13-2015 12:18 AM
