1998 4Runner Limited Shock Replacement - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-14-2003, 10:47 AM   #1 (permalink)
frederickg's Avatar
I am in the middle of installing new Bilstein shocks on the front and rear of my new 4Runner and have run into quite a snag not to mention a lot of frustration.
I have a spring compressor and everything but the darn thing is a real pain to reinstall.
Especially when you trying to keep from tearing up your shocks which I'm not sure is possible because the spring compressor digs into it as you try to crank it up.
The angle of the lower shock joint doesn't allow you to get a lot of force to leverage the shock in so you can get the bolt in either.
All insights would be much appreciated.
Thanks!
frederickg is offline
Old 04-14-2003, 11:05 AM   #2 (permalink)
4Runna's Avatar
Hey Frederick,
Weird timing. I just placed an order for Bilsteins at Central 4WD in Kent and I'm having them installed there as well. $100 for the installation.
I saw some earlier posts on Bilsteins so you might want to do a search on Bilsteins or search Corey's site.
Good luck,
4R
4Runna is offline
Old 04-14-2003, 11:44 AM   #3 (permalink)
TDiddy's Avatar
Send a message via AIM to TDiddy Send a message via Yahoo to TDiddy
Hey welcome to the boards. Are you compressing the upper A arm when you go to re-install the fronts? If not, that will be a big help. Use a small bottle jack if you have one. If not, they're fairly cheap at a local auto parts store.
Check out Steve's write up for a front spacer install for pics of what I'm talking about.
Good luck!
TDiddy is offline
Old 04-14-2003, 12:19 PM   #4 (permalink)
HBoss's Avatar
Yes, use a jack to help you.
When I had my coil/shock assembly out, it took 3 guys to put them back in. One to push the A-arms down, one to hold in/line up the lower shock mount hole and the third guy to bolt it in place.
__________________
1997 4Runner Ltd. Bilstein shocks, rear E-locker & riding on 32s.
Mods Pics
Tech articles, write-ups & more are available on my website.
http://www.hboss.net/4runner
HBoss is offline
Tags
0n, 1997, 4runner, 96, assembly, installation, order, rear, removal, replace, replacement, shock, shocks, spring, video
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
SES light!! 1998 4runner limited 3.4 07sbock 95.5-2004 Tacomas & 96-2002 4Runners 2 06-07-2007 10:00 AM
1998 4Runner Limited For Sale stlthxlr8r The Classifieds GraveYard 10 05-01-2007 03:03 PM
FS:1998 Limited 4Runner $10K VA Lghtemup The Classifieds GraveYard 9 03-21-2006 02:04 PM
Help! 1996-1998 4WD Limited 4Runner People! sschaefer3 95.5-2004 Tacomas & 96-2002 4Runners 11 05-20-2003 10:49 AM
2009 InternetBrands, Inc.
