1998 3RZFE Burnt Exhaust Valves
Old 03-14-2008, 10:26 AM
zlathim's Avatar
I've been working on a friends 98 Tacoma recently and I thought I would share. Many thanks to mustang67408 over on the Tundra Solutions board for his advice and support. He has really helped me out.
When my friend brought the pickup over to me it was missing pretty bad. After checking the basics, I ran a compression test on it and found the following very low compression on cylinder #1 (like 100 psi lower than the rest of the cylinders). A cylinder leakdown test revealed a leaking exhaust valve (or two).
So I made this:
Look like this:
So I could dissassemble this:
Before teardown I measured and recorded the valve clearances. All of the exhaust valves were too tight. I knew that only #1 had burned though because of the compression test.
Here's what the valves looked like when I got them out:
The valve on the left is obviously more burnt than the one on the right, but I am going to replace both valves. I am now in the process of deciding whether I want to have new seats installed or just lap in new valves to the existing seats. My buddy is going to sell this pickup and get one with a 3.4 V6, so he wants to spend as little money as possible for repairs.
Does anyone here have any advice or comments?
Old 03-14-2008, 10:37 AM
toytech76's Avatar
I wouldnt replace the seats. They should at least be ground to make them right
Old 03-14-2008, 10:43 AM
zlathim's Avatar
I thought about that, but if I remove metal won't it affect the overall installed valve height? What if I grind the seats and then even the narrowest shim won't allow for correct valve clearance?
Old 03-14-2008, 11:43 AM
RacerX's Avatar
you can have the valve itself machined to correct the height problem...
Old 03-16-2008, 12:28 AM
zlathim's Avatar
Yes, that is true. This was a budget project that I wanted to complete this weekend, so I was trying to stay away from the machine shop and related expenses/delays if at all possible.
mustang over on the TS board advised me to try lapping then in good. I gave it a shot, and after a few minutes the seats cleaned up pretty well:
With the new valves and newly lapped seats, I installed the springs. Then I turned the head upside down and filled the combustion chamber with solvent. In the picture you can see my compression tester adapter acting as a plug for the spark plug hole:
After several minutes of that with only very minor seepage, after 10 minutes not even a drop had formed in the exhaust runner,but it was visibly damp. After cleaning th mating surfaces on the block and head, the head went on and then the valves needed to be adjusted. I had read the FSM and measured all valve clearances before disassembly, so it was a simple matter of measuring the existing shims and comparing those two numbers with a chart to get the sizes of shims needed for correct clearances. I had to guess what shim would be appropriate for the two new valves, and I got one of them right and one wrong. I had to make an extra trip to the dealership, but all the valves are perfect now. The shims sit in buckets on top of the valve stem/springs. If you look close, you can see the setup in this picture. The valves on the right have the shims installed, the left side have empty buckets.
The FSM calls for two SST's for the adjustment proceedure, but they are for swapping shims with the cams in place. You don't need then when the camshafts are removed from the head. In my case, it would have been nice to have them because I ended up removing the exhaust camshaft an extra time in order to reshim the one new valve.
I have the whole thing put back together and full of antifreeze, but I am going to wait until tomorrow to fire it up and check everything out. It is late and my kids are asleep. I will give an update tomorrow after she's purring like a kitten.
Old 03-16-2008, 01:41 AM
NwRunner's Avatar
This is really helpful, After having a constant misfire and after replacing every other part that doesnt require dissasembly, i am about to do this myself. I have the tools and the resources, but i am fairly inexperienced with the internals of a motor, this really gave me a preview of what im gunna see, keep it up!
Old 03-16-2008, 04:41 AM
SEAIRESCUE's Avatar
You da man. You did what I would have done on a budget. Nothing wrong with lapping valves. Tough lesson in overhead cam engines where, in time, the valves will retract into the head and loose their clearances. That is most likely what fried the valves. On the 22re's I have been fairly successful in adjusting the valves and driving it for awhile. Sometimes the valves will seat, sometimes they are too far gone and a lap job is in order. I would have lapped them all but that is time I don't think you have. Smart to have done a compression check before tear down.
Old 03-16-2008, 08:44 AM
zlathim's Avatar
I hope it helps, feel free to pm me if you have any specific questions. Be sure to run a compression test before teardown, and also a cylinder leakdown test if possible. Also, remeber to measure all valve clearances before removing the camshafts. You'll need those numbers to calculate the correct shims if clearances are not in spec. After doing all that I knew exactly what to look for when I got it all apart.
Thanks for the kind words. I did replace the two exhaust valves on #1, but not the seats. You are exactly right about the diminishing valve clearances with wear. All of the exhaust valves were at about .005" clearance, when they should have been at least .010". Lucky that only one cylinder was burnt. I did think about lapping all of the exhaust valves, but I ended up trusting my earlier compression test and letting them go. I just adjusted the clearances after reassembly. I started it up this morning and it runs very good with no miss.
Old 03-16-2008, 10:54 AM
zlathim's Avatar
After two cycles of warm up to operating temp and then cooldown, the engine is running as strong as can be expected from a four cylinder and the nagging miss is a thing of the past! I am very happy with how this worked out. I owe a great debt of gratitude to mustang67408 form the TS boards for all of the technical advice and encouragement. He truly knows his shi'ite and was very happy to help me out.
I hope this simple write up helps someone in the future. I spent a total of about 12 hours over the course of 4 days to get this thing done. I would rate the job at about a 7 on a scale of 1-10 for difficulty. It definately wasn't easy,but it is very doable for someone with average mechanic skills. If you need help changing your sparkplugs, this probably isn't a job you want to take on
Blamalam
03-12-2022 07:34 AM
the1998sr5
15
07-14-2020 08:35 PM
Athansinis
07-27-2015 08:38 AM
the1998sr5
07-16-2015 06:20 AM
Quick Reply: 1998 3RZFE Burnt Exhaust Valves
