1997 Toyota 4Runner 4x4 6 cyl cranks but wont turn
omg im having such a hard time! my 4runner has been out for a week. ive replace the starter, fuel filter, efi relay and had new wiring put in from the battery all the way to the starter. it still wont turn over. it acts like it wants to and tries but just wont. i can hear the fuel pump when i turn the key. what else can be wrong?!?! please help!!!!
Did you change both the ground and hot wires from the battery? All connections good? If everything in the starting system is good, you could pull the spark plugs to see if there is coolant in one of the cylinders causing a fluid lock situation.
Any more info or symptoms that happened shortly before this? overheating, smoking, hard starting etc?
sassy4runnerchic
18
06-06-2002 02:21 PM
