1996 Toyota 4runner Limited Oil drain plug Size
My 1996 Toyota 4runner Limited factory OEM oil drain plug(see attached photo) fell off from the Oil pan.
It has always attached to the Oil pan and can't be remove only loosen to drain oil.
I purchased replace oil drain plug from local autostore in sizes of M12X1.25 AND M12X1.75, none of them fit into oil pan hole.
What is the best replacement for this factory OEM oil drain plug.
Thanks,
Paul
Thanks,
Paul
I used this for my 2000 3.4:
http://fumotousa.com/results.php?mak...nner++3.4L++V6
They have them for the 2.7 also:
http://fumotousa.com/results.php?mak...r++2.7L++4+cyl.
JaredL
06-16-2015 04:47 PM
