1996 Tacoma problem with clutch
I have to push really hard on the clutch to start the truck. All the way back plus some. If you know whats up I would appreciate the info. I was going to check the fluid but i couldnt figure out what reservoir was it. I know there is the brake res and the clutch res next to each other. I thought it my be a good idea to bleed but i dont know how. Any tips. Thank you for your time.
Last edited by moaky; 12-09-2008 at 08:16 PM. Reason: thread needed more information
Its not the resevoir, it's the pedal itself. For whatever reason its not hitting the clutch switch. I Mine does the exact same thing. I usually start it with the clutch cancel so it doesn't bug me. If you want to fix it, look under he dash and there's a little plastic clip that snaps into the pedal that when pushed depresses the clutch switch. Just put a longer clip in so it hits the switch sooner. I don't know if I'm making any sense. Just look at the pedal itself and push it with your hand while your under the dash, You'll see what I'm talking about.
Seattle_Sign_Guy
07-12-2015 12:38 PM
Poncho0206
07-10-2015 06:21 PM
