1989 Toyota 4x4 Clutch??? Button - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-23-2005, 07:58 PM   #1 (permalink)
Folowing up I bought the 4x4 for my son and we did a tuneup all seems to be well. I have a question. To the left of the steering wheel on the dash is a button that is almost all worn off from use. All we can read is Clutch........
What is this and what does it do?
Thanks in Advance
B
BMan is offline
Old 01-23-2005, 08:00 PM   #2 (permalink)
rimpainter.com's Avatar
It disables the clutch start feature, which means you can start the truck without pushing in the clutch. By enabling this, you can get moving in steep or slippery conditions without using the clutch and having the truck in gear.
rimpainter.com is offline
Old 01-23-2005, 08:01 PM   #3 (permalink)
Man that was fast thanks for the reply......
BMan is offline
Old 01-23-2005, 08:02 PM   #4 (permalink)
No problem. Good luck with the truck.
Old 01-23-2005, 08:31 PM   #5 (permalink)
Joyota's Avatar
Send a message via AIM to Joyota
I know 96 Runner already answered your question, and it's exactly what he said, but I thought I'd elaborate by quoting the owners manual.
"CLUTCH START CANCEL SWITCH
To crank the engine without depressing the clutch pedal, push the switch with the ignition on.
The switch stays on as long as the ignition is on. And it will automatically turn off when the ignition is off.
This switch cancels the clutch start system, which is designed to keep the starter motor from operating if the clutch pedal is not depressed all the way down.
The switch allows the vehicle to be driven out of difficult situations by cranking the engine with the clutch engaged.
Never use the switch for normal engine starting."
__________________
~ Joe ~ '89 4WD Pickup, Std Cab, 22RE, W56, 4.10's
{REPAIRS} Head Gasket, Timing Chain Guides, Water Pump, Alternator {MODS} Flatbed, Turn/Parking Light, SR5 Cluster, SR5 Lighter, SR5 Clock, 750W Inverter {ACCESSORIES} 33x12.5 on 15x8's (no lift), Radar Detector, CB, Contico Tool Box, Pilot Driving Lights, Fiamm Freeway Blaster {WAITING} Portable Air Tank, Big 3, Hood Scoop
Joyota is offline
Old 01-23-2005, 09:56 PM   #6 (permalink)
Plays_with_Toys's Avatar
Oh man.... I hope its not like my experience. The previous owner in my truck used the button everytime he started the truck, always with the clutch in, but for whatever reason, always used the button. Anyhow. At 90K miles, the truck needed a new clutch. I bought the truck with 78,000 miles... $700 later, I was a little pissed.
I hope thats not the case on your truck though, you'll know it if the clutch is going bad though.
__________________
1987 Xtra Cab (4x4) - (SOLD) 22r, Rancho RS 5000, 15x8 American Racing AR-23s w/ 31x10.5 BFGoodrich A/T's, 2.25" exhaust w/ 23 1/8" glasspack, Explorer Pro Comp Prerunner bar/ Hella 500's
Plays_with_Toys is offline
Old 01-23-2005, 10:01 PM   #7 (permalink)
Glenn's Avatar
No, it's got nothing to do with how fast the clutch wears out. That problem rests entirely with the previous owner's driving habits.
__________________
-Glenn-
Glenn is offline
Old 01-23-2005, 10:01 PM   #8 (permalink)
superjoe83's Avatar
Send a message via AIM to superjoe83
why would doing that wear out the clutch?, i think the previous owner didn't know how to drive a manual transmission vehicle
EDIT: i was beat to it
__________________
- Joe
1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks
1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 50W ballasts and 50W DL50 Philips 3900k bulbs
superjoe83 is offline
Old 01-23-2005, 10:01 PM   #9 (permalink)
Brendan's Avatar
Send a message via MSN to Brendan
so, when would you want to use this feature. i have the switch and have never used it.
__________________
1992 "Truck"
1978 Land Cruiser FJ40
pig and elephant DNA just won't splice :(
***DO NOT CLICK HERE***
Brendan is offline
Old 01-23-2005, 10:11 PM   #10 (permalink)
Yamaha+Toyota=Fun's Avatar
I disconnected the switch on my clutch pedal, so now everytime I start my truck i press the clutch cancel start switch. It's my security system.
__________________
92 pickup... sold
90 integra- b18b turbo, intercooled, 10 lbs of boost, 240 whp... blown up
79 2wd yota pickup
Yamaha+Toyota=Fun is offline
Old 01-23-2005, 10:21 PM   #11 (permalink)
jimbo74's Avatar
Send a message via AIM to jimbo74
Quote:
sometimes due to advers conditions it is desirable to start the vehicle in gear
jimbo74 is offline
Old 01-24-2005, 08:22 AM   #12 (permalink)
4Crawler's Avatar
My '85 did not have the clutch cancel switch to start with. Off-road, I routinely start in gear. Saves wear and tear on the clutch and if you are stopped on a steep hill, it is much easier and safer to just turn the key and go, instead of playing with the gas, brake and clutch pedals.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 01-24-2005, 09:22 AM   #13 (permalink)
seaflea's Avatar
I have used mine for many different reasons. The last time I had to use it I was 3 hours from home and the slave cylinder went out. So, I was in the middle of nowhere and had no way of repairing it! I used the cancel switch to start in gear and drove home without use of the clutch. Luckily I only had a couple of stops before I made it home!
__________________
Will
WabFab Off-Road, LLC
Toyota 4x4 Parts and Custom Fabrication
updated website with lots of new products
87 runner with every bolt on available
seaflea is offline
Old 01-24-2005, 11:06 AM   #14 (permalink)
What were you doing to shift? revving the engine high and slamming it in? I know my bro did that every now and then in his mazda... 3 months later he replaced the clutch
__________________
Old 01-24-2005, 11:11 AM   #15 (permalink)
Yeah, you can actually shift really carefully by dropping the revs and getting it into gear. Not a good practice of course, but when you are stranded it makes sense. I would rather replace my tranny than leave my truck in the middle of nowhere for sure.
It is actually good that someone mentioned this because I never really thought that would work (starting it with CSC after the slave went out).
Hopefully I will never have to use it for that reason. :pat:
Old 01-24-2005, 12:43 PM   #16 (permalink)
mike_d's Avatar
if you do it right, you don't ruin anything. get up to speed, back of the throttle a little and put it into neutral. then lightly press the shifter to the next gear. the syncros will start getting the next gear to the right speed and as the engine speed drops it'll just slide into the next gear. downshifting is harder (at least for me it is). i learned this way back in high school. i had an old CJ-5 with a heavy clutch in it. after cross country practice my legs were so tired that i couldn't get the clutch in without cramping up. so i learned how to shift without the clutch. i still do it if i'm driving home after a hard workout and don't really feel like lifing my left foot up.
__________________
mike
'89 4Runner DLX: 2" OME rear springs, 1 5/8" RB BJ spacers, Diff Drop, 32" MT/R.
'90 4Runner SR5: Stock Suspension, 32" MT/R .
'07 4Runner SR5: 2" OME Rear Springs, Donahoe Coil Overs, Total Chaos UCA, 275/70-17 MT/R.
'76 Jeep CJ-5: 4" Lift, 33" BFG MT.
'87 Saab 900S: All stock
'99 Subaru Legacy GT: All stock
mike_d is offline
Old 01-24-2005, 01:58 PM   #17 (permalink)
seaflea's Avatar
I was wondering if I should say anything about shifting without the clutch. It did get me home and as Mike D and 96 runner said you have to be careful. I learned this in an old 66 mustang that I had. The clutch slave arm would sometimes come off ( dont ask) and I would have to go home with direct drive.
__________________
Will
seaflea is offline
Old 01-26-2005, 07:37 AM   #18 (permalink)
GodwinAustin's Avatar
Hey can youy guys give specific examples of when you use the CST? I am still kind of confused on when I would use this....
so the truck can be started in gear right? is this only when its moving? I dont see an advantage of this other than not pressing in the clutch - if you were stopped on a hill you would still have to be in neutral anyways to start the engine without stall correct? so the only thing the CST is is avoids having to push in the clutch pedal? I dont see how that helps things other than being one less thing to do....??????
I just am having a bit of trouble connecting the dots here.
__________________
-Jon Red 88 4runner - 5Spd - 22re
GodwinAustin is offline
Old 01-26-2005, 07:48 AM   #19 (permalink)
4Crawler's Avatar
In gear (usually 1st gear, low range - i.e 4L), clutch pedal out (i.e. not pushed in), then turn the key to Start and once the engine is running, back to the On position and you are moving.
The alternative, is e-brake on and probably brake pedal depressed, tranny in neutral and/or clutch in, start engine, then as you let out the clutch and apply some gas and release the brake and e-brake as the engine starts to pull you forward.
A lot of time on the trail, especially in a big group with lots of stopping and starting, I won't use the clutch all day. I'll start in gear and stop in gear by just turning the key off. Saves a lot of wear and tear on the clutch and in low range, the starter can easily move the truck, in fact folks have been known to use the starter as a "poor man's" crawler gear to get over tough spots.
Find an empty parking lot somewhere and give starting in gear a try.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 01-26-2005, 08:21 AM   #20 (permalink)
Thanks Roger - thats helpful -and I guess that the only way I am really going to figure it out is to, like you said, go try it out myself...
I dont understand how the "starter" can move the truck forward though without giving it gas while in gear
__________________
Old 01-26-2005, 08:50 AM   #21 (permalink)
4Crawler's Avatar
You may need to give it a little gas while starting in gear, but not much. The key is low range, 1st gear. You should be able to idle along in gear, if so, you can start in gear as well.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 01-26-2005, 10:15 AM   #22 (permalink)
roger's Avatar
Because the starter has a little gear that meshes with the flywheel. If the clutch is engaged (i.e. clutch pedal not depressed) this will thus move the drivetrain.
__________________
Looks like I picked the wrong week to stop sniffing glue.
roger is offline
Old 01-26-2005, 10:29 AM   #23 (permalink)
ahhhh - making much more sense now thanks for those replies roger - and ummmm roger...
4low - 1st makes sense -
ok - so you stall on a very steep hill in second/4high you should apply the ebrake - clutch in > shift into 4low and 1st gear...then press the CST button and turn the key? and you are (hopefully) off to the races?
CST should only be used when in 1st/2nd 4low?
man - this is confusing....it looks like I picked the wrong week to stop snorting amphetamines.
__________________
Old 01-26-2005, 02:37 PM   #24 (permalink)
why shouldn't the button be used all the time. Just wondering
sand rippa is offline
Old 01-26-2005, 02:57 PM   #25 (permalink)
4Crawler's Avatar
No reason it could not be. Not needed though unless you plan to start w/o pressing the clutch in or if the interlock switch goes bad so that you need to bypass it w/ the Clutch Cancel Switch.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
1989 toyota 4x4 for sale exoman The Classifieds GraveYard 11 05-18-2007 01:48 PM
1989 toyota 4x4 for sale exoman The Classifieds GraveYard 14 11-29-2006 04:32 PM
Napa Clutch vs. Toyota Clutch (94 SR5 4x4) sunflower Maintenance & Repair Archives 8 05-08-2005 01:57 AM
1989 Toyota 4x4 Vaccum Hoses A Mess. Help! MIKE374 95.5-2004 Tacomas & 96-2002 4Runners 3 12-14-2002 04:10 AM
2009 InternetBrands, Inc.
