Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
1988 IFS Downey 2" rear and ball joint spacers installed TODAY! QUESTIONS!
Well I got the front ball joint spacers installed in under an hour per side with NO problems at all, a 4" angle grinder is the way to go! The rear were a little harder, the front bolts were not coming out of the old springs, so I had to grind them off and find replacements, other than that and a few hours of 100 degree garage time my truck is 2" taller than it used to be! I do have one problem though, my passenger side is about an inch lower in the front than the drivers side????? I did smack a large rock a few weeks ago and blew my front end way out of wack, I am just hoping I didnt bend the frame. Once you install the ball joint spacers how much did you all have to back off the torsion bars? I gave mine a few cranks on the passenger side and a few more on the drivers side to level it out, I am still concearned there is damage up front that I am not seeing! I am taking it in for an alighnment in the morning and I am going to have the tech check teh front end out. Any input before then would be great in case I have to make some more adjustments or replace any thing elsse! Thanks again, Matt
| Sponsored Links |
#2 (permalink) | |
Quote:
__________________
Brian 1998 4Runner SR5 |
#3 (permalink) | |
Quote:
Brian is right about the bars. Adjust till level and have at it. Frank |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1.5" ball joint spacers | dvers777 | Axles/Suspensions/Tires/Wheels | 1 | 07-29-2006 08:37 PM |
| 2nd Gen. Upper ball joint spacers 1.5" and rear coil spacers 2" | -MaTTi- | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 10-09-2004 11:21 AM |
| ball joint spacers and shocks questions and HELP! | Ilovemountains | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 07-22-2004 12:28 PM |
| 86-95 IFS Ball Joint Spacers | elripster | 95.5-2004 Tacomas & 96-2002 4Runners | 45 | 05-19-2004 05:14 AM |
| Installed: San Diego Off Road Solutions - Elripster: 1986-1995 IFS Ball Joint Spacers | sschaefer3 | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 03-18-2004 08:47 PM |
