1985 toyota truck w/ blown headgasket... - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-25-2004, 05:17 PM   #1 (permalink)
I found a 1985 4x4 truck w/ a blown head gasket. They are asking 1,000 for it. Is it worth buying to fix and just wheel it? They said it has the 22re in it is that true or is the 22r? Thanks any info helps.
P.S. are head gaskets hard to replace? How much?
__________________
1993 Toyota Truck... Blue 22re w/145,000 5 speed
31x10.50 BFG Mud Terrains
Bilstein Shocks
15x8 Black Rockcrawlers
K&N Airfilter with drilled out airbox.
Black TJM T17 with PIAA 520's mounted on top!
more soon!!
93bluetoyota is offline
Old 10-25-2004, 06:01 PM   #2 (permalink)
kyle_22r's Avatar
how's the condition of the rest of the truck? if it's good i'd say it's not a bad deal if you're mechanically inclined. both the 22R and 22RE were available until '87 or so in 4x4s(EFI was an option)
the head gasket is easy to replace, you just unbolt the intake and exhaust manifolds, unbolt the head, clean it up and put a new one on. i'd imagine it's kind of tedious with the engine in the truck, though
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 10-25-2004, 08:00 PM   #3 (permalink)
85TurboRunner's Avatar
if the rest of the truck is in good shape then id say its worth it, i bought my 85 4runner for $1200 and it had a blown head gasket, but there isnt a spec of rust on it and everything works on it.
__________________
1985 4runner 22re 5spd.
85TurboRunner is online now
Old 10-25-2004, 09:58 PM   #4 (permalink)
Yeah I agree with both of you guys. I haven't got ahold of the owner yet so we will see what comes up.
__________________
Bilstein Shocks
more soon!!
Old 10-26-2004, 07:21 AM   #5 (permalink)
22r= carb, 22re = fuel injection.
Head gaskets are not hard to replace. The thing that people need to keep in mind is that you should get the surface of the head check to make sure it is not warped. If it is you will just blow the new gasket. If you get the little bugger apart to replace the hear gasket you may as well replace the timing set while you are in there. I've picked up more than my share of Toys cheap because of broked timing chain guides.
tris66 is offline
Old 10-26-2004, 07:45 AM   #6 (permalink)
Blackulua's Avatar
If the suspension,frame,interior & body is pretty good to last for another couple years.The tires,rims,motor is easy to replace.Buy it if you can afford to repair & replace what is needed to make it run.
__________________
Black 1988 4wd Pickup 22re / White 1988 4wd 22re /1990 2wd PU 22re
Blackulua is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
1985 Toyota truck winch option superman180 84-85 Trucks & 4Runners 2 03-22-2007 01:17 AM
1985 Soild front axle toyota truck rswords The Classifieds GraveYard 20 10-16-2006 02:04 PM
possible blown headgasket? Kyle95sr5 86-95 Trucks & 4Runners 9 10-04-2006 07:31 PM
Another blown Headgasket!! Yamaha+Toyota=Fun 86-95 Trucks & 4Runners 19 01-29-2006 07:42 AM
2nd Headgasket blown- what next? Drury 95.5-2004 Tacomas & 96-2002 4Runners 9 01-06-2005 03:11 PM
2009 InternetBrands, Inc.
