1985 22re EFI Engine Problems - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-28-2005, 06:38 PM   #1 (permalink)
Ive got an 85 22re w/ efi; i just recently serviced w/ new plugs, wires, dist. cap/rotar, oil, oil filter, and fuel filter. The motor will start up fine when its cold and idle pretty much fine, then when you go to move it sputters and will not go up to speed or even at all. When its warm it runs id say aabout 80% with only a slight amount of sputtering. Any Suggests ???
ktmrider37 is offline
Old 03-29-2005, 12:06 AM   #2 (permalink)
jimbo74's Avatar
Send a message via AIM to jimbo74
sounds liek the timing is off, from your description, it sounds like what my truck was doing when the cam gear jumped 3 teeth......
jimbo74 is offline
Old 03-29-2005, 05:32 AM   #3 (permalink)
Staff
Yoda's Avatar
Did it run good before the tune up?? Or was the tune up to fix the running problem? What plugs did you use? Did you short the diagnostic plug to set the timing? Have you checked compression?
Sorry, just lots of questions. My son has an 85 22RE also.
__________________
David
TLCA 14788
71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap.
76 Landcruiser FJ-40 project/parts (haven't decided)
Yoda is offline
Old 03-29-2005, 05:11 PM   #4 (permalink)
The tune up was to fix the problems and i used a general use automotive plug that was specified to fit in the make and model. I have no reset any timing...all i have done is to losen the distributor and twist it as it would to see if it sounded any better advanced or slowed up. How do i short the diagnostic plug and what will it do?>
Old 03-29-2005, 06:24 PM   #5 (permalink)
SoCal4Running's Avatar
By twisting the distributor you just changed your timing. The diagnostic plug is on the drivers fender well. It will have two wires going to it, short it out and reset your timing
__________________
'86 4runner
22RE, 5-speed, LC Street EFI head w/ cam, LC Pistons, ARP Head Studs, Downey header, Dynomax 2 1/4" full exhaust, VDO water temp guage, 01-03 Tacoma cd\tape radio with 10" Bazzoka, Downey 2" rear springs, GDI radiator, Torus fan DONE!!!!
'68 Ford Mustang Fastback
Daily driver with a built 289 and a streetfighter trans.(Retired)
98 Subaru Outback-Took over daily driving duties
MicroMatic.com
Waco93.com
SoCal4Running is offline
Old 03-29-2005, 09:17 PM   #6 (permalink)
Staff
Yoda's Avatar
There is usually 2 rubber gommets on the inside of the drivers fender (between the AFM and the coil)
The smaller one is the diagnostic plug (I think they are green)
Pull it out of the grommet, install a jumper wire (cotter pin, paperclip), set the timing (5 deg IIRC), remove jumper.
The jumper dis-ables the computer controlled timing. You are setting the base timing.
__________________
David
TLCA 14788
Yoda is offline
Old 03-30-2005, 02:23 PM   #7 (permalink)
If i reset the timing, i shuold notice a big difference in motor performance??? Is there a tread with the step by step instructions for doing this because i have never reset timing on any of my vechiles???
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
22re engine problems mathiticus Newbie Tech Section 0 04-12-2007 03:55 PM
1985 4 runner - 22RE engine - timing mark Doc279 84-85 Trucks & 4Runners 6 10-17-2006 03:25 PM
1993 22re EFI Cold / Hot Problems cgarst 86-95 Trucks & 4Runners 2 03-07-2006 01:02 PM
1985 22re EFI Engine Sputtering!!! ktmrider37 Maintenance & Repair Archives 0 05-02-2005 07:18 PM
2009 InternetBrands, Inc.
