1981 Diesel won't start.And 1998
Old 03-10-2005, 06:18 PM
4SKIN98's Avatar
My 22r diesel has 280k. I can't get it to start anymore. The motor turns over and over and over and over... no problem. It acts as if it were not gettin fuel. I don't see a fuel pump as a replaceable item. Any ideas on what it could be.
I also have my 1998 4runner, that needs to have the starter replaced/rebuilt.
Any ideas on where I can get a rebuilf kit for the starter. I'm assuming the starter is the factory one. ?Nippondinso? I will be removing it this weekend.
I own two of the most reliable trucks on earth and niether will start....
Weird.
Blair Harris
828-216-3155
Old 03-10-2005, 07:05 PM
934rnr's Avatar
This guy may have the starter contacts that you need:
http://www.4crawler.com/4x4/ForSale/ProductLine.shtml
As for the diesel I don't think it's called a fuel pump likely a called a injector pump.
No clue where to start.
I would get a chiltons on diesel toyota's.
Also adding things like kerosene to diesel will cause it not to run as well.
With a situation like that the fuel tank would have to be purged of the bad fuel.
Old 03-10-2005, 07:48 PM
the_supernerd's Avatar
Your diesel might have air in the fuel lines. I have heard of that happening.
Old 03-11-2005, 12:07 AM
DudeBud's Avatar
22r diesel if its not firing i would point to the injector pump or the glow plugs or air in the lines might have to blead the lines
Old 03-11-2005, 01:38 AM
smiljko's Avatar
I've had some diesels (daihatsu rocky 2.8td,BMW325TD) and had similar problem-look at the fuel lines-they coud be rotten and have some cracks.
Look for the fuel filter it should have a pump on top of it-pump it up,and then try to start it with few heatings of glow plugs-that should do the trick.
And yes- if you have manual idle control -crank it up.
Let us know if that helped.
Old 03-11-2005, 06:03 PM
kyle_22r's Avatar
that's a 1L engine, not a 22R
i'd say bleed the fuel lines out, check all filters, etc. no white smoke coming out of the exhaust like it's trying to start?
an1mal_69
09-08-2015 09:40 AM
seab1209
09-03-2015 05:41 PM
kelly1450
09-02-2015 12:29 PM
Quick Reply: 1981 Diesel won't start.And 1998
