| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
1987 DLX 4X4 5 Speed: Electric Flex-a-Lite,SR5 guages,Yokohama Geolander A/T+ II,Pro Comp AAL, KC Slimlites, Bull Bar, Aux fuse box, Limo Tint, Marlin Crawler Bumper, painted shell, Sirius Wish List: Safari Rack,Bigger tires, SDORI BJ Spacers, 2001 Limited 4X4 Auto:Tundra 231mm brake upgrade, Brembo Rotors, Akebono Pads, 17" 2007 4Runner wheels, Yokohama Geolander AT-S,Sirius & Limo tint Wish List: TJM Front Bumper, KC Hilites, Safari Roof Rack, Thule Cargo Box, Rock sliders, Limo Tint |
#2 (permalink) |
a fuse may be the trick... i dont know, but maybe they are on different circuits.... what else doesnt work?
__________________
Andrew J W = WJwerdnA '99 4Runner SR5 - Pioneer MP3/IPod w/Infinity all around - lifted 2.5-3in susp. - 33's to fill the gap - sliders - ISR & Deckplate, yada yada - Satoshi - AIM:wjwerdna YotaTech Profile Custom Bumper Link for sale: ??? Nothing? |
#3 (permalink) |
I haven't checked the fuse because my wife has it. I think everything else works fine, Well the Antenna does NOT go all the way down flush but I think it's that plastic cable and unrelated.
__________________
#4 (permalink) |
look in the fuse box in the engine bay and check the fuse labeled "15ACC". this is the fuse that handles the cigarette lighters
#5 (permalink) |
unrelated... according to the schematics for a 99... the power outlet in back, and the two up front each get power from their own relay...
that could be bad PWR OUTLET RELAY [ENGINE ROOM R/B] (numbers below are relay contacts for testing) 3-5 : Closed with ignition SW at ACC or ON position 1-GROUND : Approx. 12 volts with ignition SW at ACC or ON position 5-GROUND : Always approx. 12 volts 2-GROUND : Always continuity there is also supposedly a fuse in engine bay labeled "(15A) PWR OUTLET" that goes to the relay, this also could be bad your ACC circuit activates the relay, but if the ACC fuse was bad radio, antenna, wipers, and a TON of other stuff would not work...
__________________
#6 (permalink) |
Thanks for the info, now I can get more garage time and less housework time.
__________________
#7 (permalink) |
pics coming, hold on a sec
__________________
#8 (permalink) |
![]() ![]() this pics will be deleted within a month of posting....
__________________
#9 (permalink) |
The one without the cover in the front is the cigarette lighter, it's on a seperate circuit from the others. The 2 in the front with covers and the one in the back are on the same circuit. The lighter is on the ACC fuse, and the other 3 are on the PWR OUTLET fuse, chance are that's what's gone.
I have the wiring diagrams for an 01 4Runner, if you want a copy send me an email address. |
#10 (permalink) |
oops, i was wrong but close
thanks for the correction, eric and andrew
#11 (permalink) |
eric-the-red
PM Sent
__________________
1987 DLX 4X4 5 Speed: Electric Flex-a-Lite,SR5 guages,Yokohama Geolander A/T+ II,Pro Comp AAL, KC Slimlites, Bull Bar, Aux fuse box, Limo Tint, Marlin Crawler Bumper, painted shell, Sirius Wish List: Safari Rack,Bigger tires, SDORI BJ Spacers, 2001 Limited 4X4 Auto:Tundra 231mm brake upgrade, Brembo Rotors, Akebono Pads, 17" 2007 4Runner wheels, Yokohama Geolander AT-S,Sirius & Limo tint Wish List: TJM Front Bumper, KC Hilites, Safari Roof Rack, Thule Cargo Box, Rock sliders, Limo Tint Last edited by sdstud212001; 08-11-2006 at 02:06 PM. |
#12 (permalink) |
Okay so I checked the fuse for "(15A) PWR OUTLET" in the fuse panel INSIDE and it was one of those Large fuses you usually see in the engine compartment. It looked okay to me, still had copper in the window. I didn't see a PWR OUTLET fuse in the engine bay but will check again toinght.
Thanks eric-the-red for the schematics
__________________
#13 (permalink) |
then using the pics of the schematics or the pdfs, find the relay and test what contacts are do not have the expected results, it should tell you real quick what is working and what is not
__________________
#14 (permalink) |
Right on
__________________
#15 (permalink) |
Okay so i got it fixed today. It was a 15 fuse inside the engine bay. It took me a while because I thought it was the one in the dash, then I found the relay in the engine bay and that was not it. Right when I was going to give up I decided to go over them all one more time, and I found it and it was blown. So I changed it out and now they all work well.
Yotatech does it again.
__________________
#16 (permalink) |
SD,
Wait...so i was right? was it the 15Amp ACC? or was it the 15Aamp PWR fuse? Bob |
#17 (permalink) |
no,
It was the 15Amp PWR fuse in the engine bay. But there is also an ACC but that goes to the other 12V power, the one without the caps.
__________________
#18 (permalink) |
glad ya got it there... since those three outlets didnt work, and they are the only thing on the pwr outlet fuse, and all your other stuff worked, pretty much narrowed it down once ya find it
__________________
#19 (permalink) |
Yep all good now, like I mentioned it is a used 4runner I wonder what made it do that. I will watch it to make sure it stays all good.
__________________
#20 (permalink) | |
Quote:
Btw if you want those outlets to be live all the time check here http://www.yotatech.com/showthread.php?t=75183 The normal steeing has them live only when the ignition is on. |
#21 (permalink) |
Nice mod I'll have to do that soon. Thanks!
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 12v outlet for ARB fridge | Corey | General Electrical & Lighting Related Topics | 23 | 05-12-2007 01:44 PM |
| 12V outlet caps | garrett1478 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 08-09-2005 01:19 PM |
| NEW MOD - 12V Power outlet in console | ManyMods | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 08-15-2003 07:32 PM |
| Easy extra 12v outlet | Corey | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 08-26-2002 07:46 AM |
