| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
12v Outlet on '98 is dead
__________________
2000 Silver 4runner :Highlander Edition: - Tundra TRD Coils/Blue Tokico Struts w/spacer- Downey Coils/N86 Shocks - Front Dif. Drop - Rear Dif. Breather - E-Brake Extension - Tundra Calipers/Rotors - Akebono Ceramic Pads - Goodrich SS Brake Lines - LX450 Wheels w/ 265/75/16 BFG A/T KO's and Full Size Spare - TRD Exhaust - Deckplate w/ Trueflow - Hayden Tranny Cooler - JAOS Rear Spoiler - Sport Skid - '01 Tails - Clear Corners/Bumper Lights - Leather Seats - Alpine CD player |
#2 (permalink) |
put a autozone 12V in there lol
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back. 1988 Toyota P/U 4x4 22re, 1200 miles on the rebuild engine builder .268 cam pioneer CD deck 31x10.50x15 BFG A/T BAJA 100W lights on prerunner bumper KC Daylighters 100W rancho rs5000 MUD IS A VALID PAINT JOB! If not living life to the fullest, why live it? my trucks official buildup thread |
#3 (permalink) |
What I might do is just rewire his stock outlet and have it coming directly from the battery with an inline fuse and ground the negative. Any reasons not to do that for a simple fix?
__________________
#4 (permalink) |
Cig lighter has a fusible link. It's probably blown. Happened on a 96 I use to own. I just soldered it back together. Been working fine for 5 years now.
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
#5 (permalink) | |
Quote:
Thanks for the help
__________________
#6 (permalink) |
There is no fusible link for your power outlet. You have a 15 amp PWR outlet fuse. If you lost a main fuse or fusibale link you would have lost more than just your power outlet. Check the fuse with a volt meter on each side. If it's ok then check the outlet to see what you've lost (pwr or gnd). It's only 2 wires so it should be fairly easy for you to diagnose.
__________________
98 4Runner SR5, 4x4, Stock suspension/drivetrain, E-Cooling Fan Mod, B&M Trans Cooler, Alpine CDA-9887, Boston SX60, Polk Audio db651s, Linear Power 4503, Brown Bread sound deadening throughout... |
#7 (permalink) | |
Quote:
__________________
#8 (permalink) |
You sure about that buddy? Take the cigarette lighter assembly out of the dash. Look at the back of the unit. You will see a little brown "wire" hooked to it. That's your fusible link. It's probably burnt up and not making a connection. This was the problem with my 96 4Runner. I simply removed the link, and soldered a new piece of wire on.
__________________
#9 (permalink) |
if you can't figure it out, search for a few other threads, I swear I have seen this problem come up more than once in the last month. It was the same thing, fusible link (not a fuse) on the back of the socket, replace or repair. After of course you check fuses, pretty sure cig lighter and aux sockets (if you have them) are on separate circuits...
__________________
Andrew J W = WJwerdnA '99 4Runner SR5 - Pioneer MP3/IPod w/Infinity all around - lifted 2.5-3in susp. - 33's to fill the gap - sliders - ISR & Deckplate, yada yada - Satoshi - AIM:wjwerdna YotaTech Profile Custom Bumper Link for sale: ??? Nothing? |
#10 (permalink) | |
Well unless the Toyota wiring diagram is wrong..... Then yes I am sure that a 98 4runner does not have a fusible link for the pwr outlet.
Quote:
__________________
#11 (permalink) |
There is one detail thats not clear. Are you talking about the pwr outlet in the dash (cig lighter) of the power outlet by the rear door. Important to know.
__________________
#12 (permalink) |
So you've taken it apart? A fusible link in this case is not a plastic replaceable fuse as you probably think, it is just a small wire meant to fail if needed (or at random). It is meant to be replaced as a whole unit (the socket). As explained in another thread covering this same topic, it is a slow-blow link designed to protect your vehicle from cig lighter being left in, since it wouldn't (most likely) blow the main fuse. It's not going to show it on a wiring diagram
Search Google for "cigarette lighter fusible link" and see how much this topic is covered in so many forums
__________________
#13 (permalink) |
Cig lighter. Thanks for all the help thus far guys, I'll let you know what I find!
__________________
#14 (permalink) |
Just replace the outlet. It probably burned up?
If the fuse is good then the outlet is bad.
__________________
1998 4runner Limited, Locker,Black Headlights, Sport Hood,99 suspension, more to come! 2000 Ford F250 7.3 Diesel, plow and yard service truck 1999 Ford F350 6.8 V10 Dump Truck 2007 Yamma Grizzly 700 FI, Warn 2500 winch, 54" Snow Plow |
| Tags |
| 12, 2002, 4runner, 700, cigar, diagnose, ford, full, fuse, grizzly, lighter, mod, outlet, power, time, truck, volt, yamaha |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 12v Power outlet question | Red3.slow | 86-95 Trucks & 4Runners | 14 | 02-07-2008 11:06 PM |
| Where to wire a 12v outlet? Battery only? | Hugo | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 09-27-2007 05:17 PM |
| 12v power outlet question | sdstud212001 | 95.5-2004 Tacomas & 96-2002 4Runners | 20 | 08-12-2006 11:11 PM |
| 12V outlet caps | garrett1478 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 08-09-2005 01:19 PM |
